New Vera Edge - Energy Tab not working
I just got the new Vera Edge 2 days ago and set it up with a few appliance switches (2 Aeon Smart, 1 GE outdoor).
I activated the Energy tab, which installed the Ergy plugin, but when I click on the Energy tab all I get is this error:
Could not find gateway from: SerialNumber: xxxxxxxx
Anyone seen this or has an idea?
Thanks,
Raladic
Hi, I’m also new VeraEdge owner and can confirm that I have the same problem. I have emailed support but have not received any feedback.
I believe you have to pay for this service and configure this with the Vendor.
When tech support was trying to fix my VeraEdge, I saw all sorts of stuff on their dashboard…they have packages for security, energy, etc. coming I’m sure of it.
Ergy is the service but they won’t let you sign up directly…it has to come from Vera :frowning:
I am having the same issues. I have called tec support and emailed unable to get a hold of them
same issue on mine.
Support got back with me. Usb issue should be in update end of week. Far as engery issue vera support started a case with engery support and said will let me know. Will post if get a answer.
Ergy states on their website that their plug in is currently not operable and they are not allowing new signups at this time. They have an add email option to notify when it is working again. I can confirm that with vera edge I get the same result and on UI7 on my Veralite while it works initially is just constantly restarts my controller and had to be removed. It bricked my veralite several times requiring a firmware reset. I have had nothing but problems with this feature as MCV points finger at ergy and ergy points finger at MCV. Expect that response from MCV support, while it is a tab within the UI it is driving by a plugin created by an outside vendor. They treat it no different that any other plug in created by any other developer which is BS since they have made it part of the firmware so they should shoulder more responsibility.
Hello. I see that the energy tab is doing the same thing on my veralite. I have noticed other members of the forum were able to post pictures of energy graphs with a smart switch. Is that part of the energy tab in the older UI’s? I can’t find anywhere that will show me a graph. If this is a limitation of UI7, is it possible to roll back to an old OS?
I’m only a week in to this, I apologize if I sound naive.
Thanks,
Eric
Some are using the plugin datamine (not in development anymore), Eventwatcher plugin or collecting data and graphing it themselves.
  • Garrett
I figured it out, I ditched UI7 and rolled back to UI5. Now I have a meter. This is much better! Thanks
edited typo
It looks like the latest firmware has made some change, now I’m seeing a different error:
Key does not match ErgyKey: xxxxx
Anyone else having more luck?
Support got mine working on the vera edge, it is a bit buggy but the app has also not been updated since feb so hopefully ergy will update the app in the near future. Firmware 1.7.906.
[quote=“Raladic, post:12, topic:184651”]It looks like the latest firmware has made some change, now I’m seeing a different error:
Anyone else having more luck?[/quote]
I get the same ErgyKey error on veraedge
[quote=“JS007, post:14, topic:184651”][quote=“Raladic, post:12, topic:184651”]It looks like the latest firmware has made some change, now I’m seeing a different error:
I get the same ErgyKey error on veraedge[/quote]
removing the “ERGY Plugin” and re-accepting it on the energy tab seems to have corrected issue
This tab is not working for me. I bought an Aeon Labs HEM and I entered the cost per KWH in settings. I see nothing under the energy tab. Occasionally, I’ll see the outline of a box that says "retrieving"but nothing ever populates. I have seen a message that says something like “it’s taking too long to retrieve data, what do you want to do” with options to reload or cancel. None of the options do anything. I submitted a trouble ticket but have not heard back. Has anybody seen any real usefulness from UI7’s energy settings?
Thank you,
Jason
looks like the error came back, so still not working
I’m also getting “Key does not match ErgyKey”
If anybody has made The Vera Lite work as advertised I’d like to hear about it. Both products look good on paper but the proof is in the pudding so to speak. Obviously Vera support guys are over their head and need to take stock on getting the basic Apps like Energy and what ever else is second working out of the box.
Vera Lite UI7 Energy Tabs are useless until somebody delivers an App for the neat $25 Aeon Labs DSB09104-ZWUS - Z-Wave Smart Energy Meter. That solution would be a best seller when supported with a YouTube how-to video.
Larry
Vera works great for me!
Thanks for asking.
