Good morning Vera community. I have been using a couple of Vera3 controllers to control Schlage Z Wave touch pad door locks on a coupe of separate condos I have at the beach. It appears that the I have been having issues with batteries. When I log into the app, it shows my battery life as good on the lock, but I don’t think that is the case. I can change the batteries and the locks work again. I wondering if I am not logging in enough to get an accurate reading of the battery life on the lock?
Also, If I turn off polling to get more life on the batteries, would it still communicated battery life?
Thanks for the info. So let me make sure my setting are correct:
I uncheck poll nodes
Number of seconds to wait to start polling is set to 20
Only poll a node if the Z Wave network is idle is set to 10 seconds
Unless specified otherwise, poll each node once every set to 60 seconds
Poll a node every ) seconds.
So I don’t see a setting on the lock for a wake up interval. Keep in mind I only have one device on the network which is the lock. I went to the settings on the device, which is the lock, settings and I only have the option to Poll this node ever _ seconds
I can’t tell you. It’s been several years since I installed them. Not at the location where the units are located. Is it possible to tell you that through the web interface?
I believe it is the green writing if memory serves. I have 4 of them.
Firmware is 1.7.569
These things have been bullet proof so I have been apprehensive about updating them
So would updating the firmware give me the ability to do that? I see that the poll setting on the device is set for 10800 or every three hours. So by setting that to 86400 that would once a day right?
“So would updating the firmware give me the ability to do that? I see that the poll setting on the device is set for 10800 or every three hours. So by setting that to 86400 that would once a day right?”
No poll setting is different to wake up interval.
Well if it is that model here is the installation guide for it and its product page [broken link removed].
The guide make no mention of any Z-Wave settings at all.
Usually Z-Wave device user manuals mention the wake up and sometimes what its max value can be as some you cannot set as long as 86400 seconds.
fair enough. so if the polling number on the lock is 10800 meaning it polls every three hours. I just changed the setting to 86400 on the device meaning it would only poll once a day right?
