Not empirical evidence, but…
Alarm systems have had Wireless sensors for many years now. These tend to operate on lower frequencies (like 433Mhz) as compared to their Z-Wave counterparts (~900Mhz). Both are subject to interference, like @strangely and his Oregon Scientific weather unit vs others with Baby monitors
Alarm system components tend to be built to avoid callouts, since that’s costly for the vendor, and frustrating for the end-user. If we could get the #'s, I suspect we’d find that their [battery operated] Z-Wave counterparts haven’t had nearly as much mileage in this space - especially if they’re used for Automation more than Security.
I’ve used both the HSM-100 (“3 in 1”) Motion-Light-Temp as well as the HomePro ZIR-000 and, both failed my test of reliability (the HSM-100 was better, but still flakey). Others have successfully used the HSM-100’s, and some have gone as far as wiring them with a local Wall-Wart to avoid changing batteries.
For the few wireless Alarm sensors that I have, they’re built to a whole other standard of quality as compared to what I’ve seen in the Z-Wave space and, depending upon the brand, they’re often cheaper than their Z-Wave counterparts.
Also, for some of the Panels there’s a wide array of competing Sensor devices. I think people would love to see these come down for automation use (Z-Wave), and hopefully we’ll start to see that with some of the Alarm vendors moving into this space.
Overall, for the supported Alarm integrations, each system will operate independently. When Vera fails, the Alarm system will continue to monitor the devices. When Vera comes back up, it will discover the “current state” of the sensors and get them all in sync.
All these security and/or automation sensors tend to show up in Vera as the same type of device. From a Vera/Scripting standpoint, it won’t matter whether the MotionSensor is a Z-Wave one, or one synthesized by an Alarm System Plugin, they both look-and-feel the same.
That said, because the systems are independent, it may not be possible to have the Z-Wave sensor trip the actual Alarm Panel. Again, they’ll all look like motion sensors to Vera/MiOS but they often([sup]*[/sup]) cannot be exposed to the raw Alarm Panel/Board.
[sup]*[/sup] Some of the Panels support doing this, but the Plugins may not currently support it. My Panel has a “Virtual Input” capability, for example, and the DSC has something similar.
[quote=“Dolphran, post:3, topic:171694”]Thanks for your reply. Let’s assume I am not interested in hard-wired sensors that would be used with a traditional alarm panel (I’m unlikely to want to do the wiring work if it can be avoided). I guess alarm systems these days also use wireless sensors - is there any reason to believe they are more robust than the Z-Wave equivalents? If I went with an alarm panel with wireless sensors, would the Z-Wave sensors I just invested in be useless, or do these systems take input from the Z-Wave side?
I can actually see some advantage to using smart-phones to arm/disarm instead of a traditional keypad, so maybe I don’t need that aspect.[/quote]
