I recently installed a Trane T-stat and my ac system seems to cycle on more often than with the standard t-stat that was originally on it. I believe I read somewhere than there might be a way to change the degree delta that determines when it turns on or perhaps a minimum time the ac will run when triggered.
I will also take any other ideas someone might have.
Thanks for the help.
