This plugin is enabling you to check the availability of some device on your IP network. it uses ping or http to verify the availability of a device and report it as a Motion Sensor device in VERA
-Tripped: means the device is not present or fails
-Untripped: means the device is properly responding to the probe
The plugin is not yet in the App Store but you can find it AltAppStore or the sources on [url=https://github.com/amg0/NetMonitor]https://github.com/amg0/NetMonitor[/url]
To install , download the files from github , upload them and manually create the device
It is freeware but you have a donation setting page if you feel like showing your support
@amg0. A splendid plug-in. Would I be correct that IgnoreTripTime is not implemented? At least it does not seem to work in the way that I would expect. I have an IP device that is on an unreliable part of the network, so I would like to delay the alert until it has failed two pings. I set IgnoreTripTime to a value more than the polling cycle time, but it still trips, and only delays the un-trip.
Nope it is a design decision. I made the device in embedded mode so children are following it in the same room as their parent. Seemed to me a better way as they are all just a probe.
I am Not sure if this setting could be controlled by an option and changed after the initial device creation
[quote=âwilme2, post:10, topic:199119â]How do I assign a monitored device to a âRoomâ? I guess in the advanced settings if I knew the room numberâŠ
UPDATE - works via advanced settings.
UPDATE 2- nope, after a reboot, the motion sensor was back in âNo Roomâ AKA Room 0âŠ
Realization - this is parent/child and they have to be in the same room - it is a Vera limitation.[/quote]
wilme2,
Perhaps I misunderstand your query, but on openLuup/ALTUI, I moved all of the child devices into a separate room via the control panel of the child device.
If this is not what you are looking for, please ignore.
[quote=âChrisTheC, post:12, topic:199119â][quote=âwilme2, post:10, topic:199119â]How do I assign a monitored device to a âRoomâ? I guess in the advanced settings if I knew the room numberâŠ
wilme2,
Chris[/quote]
Maybe oprnluup did not fully implement the embedded flag concept on devicesâŠ
[quote=âakbooer, post:14, topic:199119â]I may be missing something, but is there a way to invert the sense of the âtrippedâ alarm?
Iâm using it to monitor by internet connectivity, and having previously used the Ping plugin, OK is â1â and not OK is â0â.[/quote]
I think the point is when a device has the embedded flag set too ne all it?s children devices are following it in the same room.
NETmON plugin uses the embedded flag so on vera all children follow their father in the same room and apparently on openluup not hence my inference that embedded flag may not be implemented on openluup. ( have not tested )
[quote=âamg0, post:15, topic:199119â]I think the point is when a device has the embedded flag set too ne all it?s children devices are following it in the same room.
NETmON plugin uses the embedded flag so on vera all children follow their father in the same room and apparently on openluup not hence my inference that embedded flag may not be implemented on openluup. ( have not tested )[/quote]
OK on that. Iâll check, but I thought that I had correctly implemented this behaviour.
However, my recent post was a separate enquiry altogether⊠how to invert the sense of the âTrippedâ variable.
Loving this plug-in. Have teamed it up with Homewave to monitor all of my Milight Bridges.
Helps flag any connectivity issues quickly and before I waste time troubleshooting scenes that arenât working.
[quote=âsk1.publicc, post:17, topic:199119â]Loving this plug-in. Have teamed it up with Homewave to monitor all of my Milight Bridges.
Helps flag any connectivity issues quickly and before I waste time troubleshooting scenes that arenât working.[/quote]
thank you for the feedback
