PM sent. I would add that the sensor has not included correctly into Ezlo plus, as it is a door sensor as well, but it only shows as a temp sensor. The temp displays correctly in Ezlo but in OpenLuup it shows as 2000.
Hello @reneboer, sorry for long delay i was optimizing my IT hardware and moving everything on one server with dockers so i finaly installed OpenLuup on docker and connected ezlo plus without problems to openluup. Butā¦
i have some strange things showing.
- i have 2 fibaro dimmers that are working fine in Vera App but in open luup on one dimmer it shows
Load error state: unknown on the second dimmer it showsHw state : unknown - on the motion sensor zigbee that i have it does not report the states but in the variables it shows
DisplayLine1 Motion : trueandDisplayLine1 Motion : false - Temperature sensor does not show any value in the interface but there is value in variable.
- the zigbee thermostat does not have any interface and controls but i think that the support for thermostat is limited⦠variables are ok and are all there.
Hi @eonnet,
Can you go to the API tool Ezlo API Tool, select your Ezlo controller and send me a PM with the out put of hub.device.list and hub.items.list? Maybe these zigbee devices show a little different than the zwave ones.
Cheers Rene
An updated version (1.03) of the EzloBridge is available to update on openLuup. Updates include:
- Added logging, variables, json and utils modules.
- Log level is a user setting.
- Removed rooms, scenes and device ID removed from stored mapping.
- Changes SID/device type to rboer.
- Added periodic full pull of devices and items for full status refresh.
- Display Canāt Detect Device message if hub shows as unreachable.
- Handle broken device status. (Message shows as Cannot reach or broken)
- Fixed issue for unwanted State variables created for Ezlo device items we want to ignore.
- Fixed duplicate creation of CurrentTemperature.
- Display Device Broken message if hub shows as broken
- Able to reconnect if VM running openLuup is restarted without needing a luup reload.
- Changed items mapping to generic sensor to item name and not all the CurrentLevel.
- Better HVAC support.
- Fix for SetArmed action as Ezlo changed value name.
- Fix for scalar type variables.
- Fix for action mapping functions.
- Some logging fixes.
You will have to remove the current bridge device and then re-install the plugin unless you have installed the development version prior.
Keep the feedback coming.
Cheers Rene
Hi Rene,
i reinstalled the ezlo bridge and recieved the following error:
8/12/2020, 2:37:12 PM #6:Ezlo Bridge:[string "L_EzloBridge.lua"]:1958: attempt to index field 'data' (a userdata value) the controller is stuck on Connecting to Ezlo Hub⦠Getting tokens from Ezlo Portal
Hi eonnet,
I cannot reproduce this. Can you check the settings?
Also set the log level to debug and let me know what is shown in the log file.
Cheers Rene
Found a quite serious bug in V1.03 it that it did not add the required device number offset (10000, or 20000, etc.). Just pushed out V1.04 with this fixed.
Hope no one messed up a key openLuup system. Lesson to learn. Make a copy of the user_data.json before installing any new plugins.
Cheers Rene
I do a Auto back up daily, i save 30 days of backups.
Thanks for the heads up. No issues here, hope every one else is ok to.
Now iām receiving the following error:
Ć 14/08/2020, 08:32:26 #4:Ezlo Bridge:[string āL_EzloBridge.luaā]:1960: attempt to index field ādataā (a userdata value)
And on ezlo bridge it displays
Connecting to Ezlo Hubā¦
Hi @eonnet,
Found the issue. I test with just Ezlo hubs on the account. In your case you have both Vera and Ezlo. I found that mixing them gives me grief and is especially not good for the WAF.
Anyhow, I just uploaded 1.05 that has this fixed.
Cheers Rene
everything is ok now, thanks.
Updated the github to V1.06 with a fix for numeric values on the Athom hubs. No changes for Linux based.
Cheers Rene
I just installed this, and its stuck on āgetting devicesā.
2020-09-14 12:43:28.823 openLuup.context_switch:: ERROR: [dev #60] [string "L_EzloBridge.lua"]:2521: attempt to perform arithmetic on upvalue 'lastFullStatusUpdate' (a nil value)
2020-09-14 12:43:28.823 luup.delay_callback:: function: 0x55e5c2170f10 ERROR: [string "L_EzloBridge.lua"]:2521: attempt to perform arithmetic on upvalue 'lastFullStatusUpdate' (a nil value)
Only one generic z-wave on the ezlo nowā¦
Hi @anon37769099,
Just pushed an update on gitub that should fix this. Please let me know.
Cheers Rene
The error is gone, but it still seems to stop at āGetting devicesā. I removed the one device connected to it (heat-it 8-switch doesnt work well with EzloPlus), but it should still show ā0 devices 0 scenesā right?
luup log:
2020-09-15 11:39:00.921 openLuup.scheduler:: [60] Ezlo Bridge device startup
2020-09-15 11:39:00.925 luup_log:60: var.GetSet: empty data value for variable IncludeDevices
2020-09-15 11:39:00.925 luup_log:60: var.GetSet: empty data value for variable ExcludeDevices
2020-09-15 11:39:00.926 luup.variable_set:: 60.urn:upnp-org:serviceId:altui1.DisplayLine1 was: Getting devices and scenes... now: Connecting to Ezlo Hub... #hooks:0
2020-09-15 11:39:00.926 luup.variable_set:: 60.urn:upnp-org:serviceId:altui1.DisplayLine2 was: [x.x.x.x] now: Opening web-socket to Hub. #hooks:0
2020-09-15 11:39:01.009 luup.variable_set:: 60.urn:upnp-org:serviceId:altui1.DisplayLine1 was:Connecting to Ezlo Hub... now: Getting devices and scenes... #hooks:0
2020-09-15 11:39:01.010 luup.variable_set:: 60.urn:upnp-org:serviceId:altui1.DisplayLine2 was:Opening web-socket to Hub. now: [x.x.x.x] #hooks:0
2020-09-15 11:39:01.010 luup.set_failure:: status = 0
2020-09-15 11:39:01.010 luup.variable_set:: 60.urn:micasaverde-om:serviceId:HaDevice1.CommFailure was: 0 now: 0 #hooks:0
2020-09-15 11:39:01.010 luup.variable_set:: 60.urn:micasaverde-com:serviceId:HaDevice1.CommFailureTime was: 0 now: 0 #hooks:0
2020-09-15 11:39:01.010 openLuup.scheduler:: [60] Ezlo Bridge device startup completed: status=true, msg=OK, name=EzloBridge
Hi @anon37769099,
Can you set the log level to debug in the plugin settings? Maybe that gives more clues. I have not tried with no devices and scenes so it could be that.
Cheers Rene
log level is at 1, set it to 0?
It is in the settings tab for the plugin, last drop down.
Ok, so:
is starts up fine, then 2 seconds later:
2020-09-16 14:28:14.041 luup_log:60: EzloBridge_debug: MessageHandler false, receiver error: closed
2020-09-16 14:28:14.041 luup_log:60: EzloBridge_debug: MessageHandler, opcode = false? receiver error: closed
4 seconds later:
2020-09-16 14:28:18.236 luup_log:60: EzloBridge_debug: MessageHandler false, receiver error: closed
2020-09-16 14:28:18.236 luup_log:60: EzloBridge_debug: MessageHandler, opcode = false? receiver error: closed
2020-09-16 14:28:18.237 luup_log:60: EzloBridge_warning: EzloBridge_Async_WebSocket_Reciever. Lost connection to Hub, closed. Try reconnect in 30 seconds.
