We are please to announce that we have launched version 1.79 of the Philips hue plugin that includes the following:
- Added support for Signify Netherlands B.V. as the manufacturer, which was added by February 24th Philips hue firmware release.
- Fixed icons for bulbs that appeared as generic Z-Wave.
- Added support for light models: LCT015, LCA001, LCT024
I know those who haven’t switched over to using the ALTHue plug-in will really appreciate this update!
not working with my bridge V2, please assist.
Hi.
I’m using hue plug in 2 , I didn’t manage to operate althue.
They are on the same network and I can control the bridge from other apps (hue, imperihome).
The only response I get is that pairing in progress for hours… I also tried manually yes…
- Can you check if it is the latest version 1.79 under Apps-MyApps-Details
- Are they wired or do you use Wifi?
And sorry for probably a silly question that you tap the blue button on the bridge also during inclusion?
I don’t remember if I had to do this.
Yes latest version 1.79
They are wired via router, not wifi.
Blue button pressed
Hmm, I left for Althue when this app crashed in february. I have not used this version so I leave it for others to figure it out but I recommend to switch since Althue have more functionalities.
https://community.getvera.com/t/althue-read-me-first-the-alternate-edition-of-the-philips-hue-plugin/198905
I will try to install ALTHUE again, I guess this is the only option for me.
Thanks for trying !!
