New Owner, New Forum member
I just got a new vera lite 3 from amazon the other day and hooked it up. I’m glad that the community here is pretty strong and i’ve already found some help through some of the posts here. It was a major reason going with the vera solution. Hopefully I can be a part of the community and learn a lot about the system and the possibles. I am a computer programmer so the luup scrips don’t look to scary.
I setup the system and I have to say that the whole experience is a bit on the tinkerer/techy side but I’m definitely a fan. I only got 1 door sensor. Once i got everything up and running, deemed it what I was looking for, I put an order in for 2 more door sensors and a light switch. My main purpose was security, but I see a lot of more uses over time. My wife wanted a security system and I didn’t want to buy a land-line, pay a monthly fee, have a system that i couldn’t change or take with us if we move. So I found the vera lite and so far it’s exactly what i wanted.
My only complaint has been the iphone mobile app. It’s a bit buggy, bombs out a lot and then has to refresh all the data. I will have to test the other apps I’ve seen out there and see if there is something better. I’d imagine that this will get better with time.
So far the non techy wife has been using the screens to enable and disable the sensors, so she is happy and therefore i’m happy.
Happy wife = Happy life
Two recommendations for apps for the ios platform is Homewave and Automator.app.
Welcome to the community!
  • Garrett
Thanks for the app tip. I just loaded both. Automator is a little pricey but man it’s nice. Very refined and very responsive unlike the free vera app.
I loaded the homewave and it looks like to initially set it up you have to be on the wifi. I like the fact that automator ties right into your MIOS login. I’m going to stick with automator. As i’m using this for security, $15 is pretty cheap to have a more reliable method of enabling scenes and getting alerts. It’s a lot cheaper then trying to get a panel like traditional security systems. Plus those are always so ugly.
If you had an android device you could have a few good free options! :wink:
  • Garrett
I suggest you check out the DSC Alarm Plugin subforum.
The DSC + Envisalink system might save you time and money in the long run.
There are no monthly fees for self-monitoring of that.
[quote=“PurdueGuy, post:5, topic:176511”]I suggest you check out the DSC Alarm Plugin subforum.
There are no monthly fees for self-monitoring of that.[/quote]
I agree. Using Z wave for security is a hit or miss solution.
Plus, using the DSC plugin, you can tie all your sensors into usable devices on your Vera to trigger events, etc.
Take a look at the deals on homesecuritystore.com. You can get a decent starter system there for a few hundred dollars.
You can do the same with both. I do use both. Automator for notifications and Homewave is the normal day to day key controller. Homewave. Provides greater flexibility is layout and that wins my wife’s over.
With Homewave, you will need to go to your through your iPhone Settings > Homewave > enter in your MIOS details.
