New Notifications not populating in Vera Alerts
I have upgraded to the latest Vera Firmware.
I have created 2 new alerts:
Description: Temp temperature goes below 2 degrees
Notify: Nick
Description: Temp temperature goes above 18 degrees
Notify: Nick
Once these are created, they are not populating in the “Notification Configuration tab”
They are reporting in the report in the Alerts report
Is there an issue with Vera Alerts with the latest Firmware?
N
If you are on the latest UI7 release you need to be on the latest Vera Alert Plugin release.
Vera alert version I have is .Current Version:6.41
Is that the latest?
I have updates set to auto update
N
Hi Richard
Is 6.41 the latest VeraAlrrts version?
N
Yes 6.41 is the latest. But if you just upgraded UI and your having problems you might want to force update the same 6.41 again.
http://YourVeraIP:3480/data_request?id=update_plugin&Plugin=3008
Enter your vera IP, make sure your on the same network as the vera and but into a browser.
Reload vera and fresh the ui and you should be good as long as your VERA UI is updated to the latest.
Super thanks. Will have to do it tonight as i have just got to the office.
Thanks for the reply!
My Vera alerts has also been broken for me since 11/26 early morning. Has the usage format changed for my code below? De-registered, re-registered, forced update of vera app, and reinstalled app from google play store.
luup.call_action(“urn:richardgreen:serviceId:VeraAlert1”, “SendAlert”,
{Message = “{tone:2} HI It’s Vera, It has reached 80 degrees outside, I will now turn on the upstairs ceiling fans when Someone is upstairs…”, Recipients = “”}, 85)
I am still on firmware 1.7.1248 and have made no updates.
Any suggestions?
**** UPDATE - After waiting a while, the Vera alerts are back again. Not sure why they stopped. Looking forward to PLEG on OpenHab ;D
Mine also broke on the 26.
I am on ui5. all seems to work in ui but no messages on the phone.
CE
See:
http://forum.micasaverde.com/index.php/topic,35007.msg258081.html#msg258081
Thanks Richard !
Working again.
Reg. CE
