New HA system, need help
I want to install a new HA system but im having trouble with what to use. My big issue is that I have a few items in my home already that allow me to control them remotely such as the wemo outlets and a filtrete wifi thermostat. The next two items I would like to add are irrigation control and remote locks.
From what I can see there the MVlite has apps that will give me access to the thermostat and wemo outlets. I also see the MVlite can be used to control the some kwiset door locks and rain8net irrigation.
My big issue is this, I cant seem to find too much on what options are available as far as customizing the events in the User interface. I researched using the ISY994i for insteon which allows quite a bit of customization including the if/then conditions, the issue is that it cant work with the WeMo and Tstat that I have. I also like the idea that I can hard wire the rain8net irrigation controls. Im not sure I am too thrilled with all of the signals going over the power lines. I am concerned with reliability since the irrigation controllers will be about 60 feet from the controller.
Any advice will be greatly appreciated.
All that you describe can be done with Vera. If the simple UI5 scene creation interface isn’t powerful enough then you can use a Program Logic Plugin to get a more complicated conditions.
