New GoControl WA00Z-1 Wireless Remote Switch
I’m using UI5 on a VeraLite. When I go to add this new controller, I get ‘failed at getting version number’. I believe this is because the Vera doesn’t yet officially support it, but I’m hoping someone can help point me to a way that I can manually add it by modifying the advanced settings.
I’ve tried to find the version info in the Zwave database, but am coming up empty handed.
Ultimately, I’d like to have this control simply activate another switch (Group 2 or 3, I think).
Any guidance would be greatly appreciated.
I just got a WA00Z myself. Did you ever figure out how to use it with Vera?
Anyone crack how to get this recognized by Vera? I just got one but haven’t had a lot of time to play with it yet…
I figured it out. Key is to add it and make sure it is seen as a switch (using genericIO definition is fine). Then go into device options and add / setup groups 2 and 3 (optional). For each group select what devices you want this remote switch to control. Don’t rely on scenes or other triggers, or at least I was never able to figure out how to use it that way. Make sure to press back and save on all necessary points. If the interface gets hung up on ‘waiting for device to update’ or other timing out type message, press a button on the switch to wake it up…
