Anyone tried one or got it to pair. I’ve tried everything but cant get it to pair. Any ideas?
Update.
Although it goes through pairing and says “Successfully exchanged security keys” it fails to complete pairing process. When I exit I see I have a _Generic IO device which appears to be what it added.
just FYI it might be a similar issue than the one faced by some people with the new Fibaro Motion Sensor… See http://forum.micasaverde.com/index.php/topic,37762.msg282149.html#msg282149
So Vera support might be your best option
They have confirmed it’s not yet supported but will in one of the future releases… Don’t hold your Breath.
I just got caught out by this.
I bought my 4th Fibaro Door/Window sensor today and it won’t work with the same issue you’re seeing. Annoying considering the others all work great.
And they said Z-wave was like the USB of home automation… :![]()
Upgraded to the newest Firmware.
FGK-10X - can’t get past ‘purging associations’.
Big red error, useless.
Tried pairing a 10X today with latest firmware. Still epic fail.
Was able to get one 10X working a late last year, but it took 20 pairing attempts.
Successfully paired a FGK-101 today.
Logged ticket with Vera Support.
Is there a way to pair it in a non-secure way? I had a similar issue with a Ecosmart sensor that would not pair until I paired it using the non-secure method.
Has anyone been able to make this work? I have two I am trying to add without luck
