New EZLO Linux Firmware pre-Alpha starts today
@reneboer, thanks for comparing notes. Your log looks similar to what I am seeing but with a different root cause. I believe the firmware maps product attributes to a device-shim script and from your logs, it seems that the firmware doesn’t know about your device or have the mapping. Sounds like the team is on it so time will tell. Maybe your idea of re-including is a good one? (edited, looks like you posted positive results while I was typing) :+1: :muscle:
Did that as soon as it hit the wild and before reporting that the issue still exists.
cat /usr/lib/opkg/info/firmware-common-git_version.control
Package: firmware-common-git_version
Version: 1.0.16
Depends:  libc
Section: eZLO Innovation
Architecture: ramips_24kec
Installed-Size: 4616
Description:  	Just firmware-common-git_version package
Absolutely. The only barrier is that in the most recent Vera Plus legacy firmware update lost a device that I need to recover/resurrect before messing with my network fabric. I’ll try to knock this off in the next day or so.
Sure - here is a region bug that I reported and still exists in 1.0.16.
And here is the one that we are discussing,
Screenshots from my V+ with the requested info are attached but it is worth noting a few observations during my exclude/include process:
  • Excluding the Zooz Zen15 on the Alpha firmware was fast.
  • Adding the Zen15 with the legacy firmware on the V+ is much slower than than the new Linux firmware on the Vera Edge. The legacy firmware has to reload the engine so the user is forced to wait for that to complete. Nice to see that is gone in the new Linux firmware.
  • Excluding the Zen15 with the legacy firmware on the V+ is slower because the legacy firmware has to reload the engine so the user is forced to wait.
  • Pairing the Zen15 on the Vera Edge running the Alpha firmware is fast and painless - no more waiting for engine reloads! I don’t know if the speed improvement is the z-wave stack re-write or the number of devices (I have far fewer on the Edge running the new Linux firmware). I’m hoping it is the new z-wave stack.
  • Power usage status updates are nearly instantaneous on for devices on the new Linux firmware. With the iOS app launched and displaying the Zooz device, I used tail -f /var/log/ha-luad.log to watch the events fire as I plugged and unplugged a power-consuming device. As soon as I plugged the device into the Zen15, the event log updated and the iOS App UI updated - the legacy firmware updates in a similar fashion but subjectively it feels slower.
  • Power usage reporting includes watts and volts on the new Linux firmware
  • Excluding and re-including a device on the Vera Edge increases the node number - shouldn’t the node numbers be re-used?
  • Excluding and re-including the Zoon Zen15 V2 on the Vera Edge enabled the power usage reporting (as @reneboer first reported), however I still see the following warnings in the log:
Float value updated, node id: 4, channel id: 0, class id: 50
2020-03-13 14:57:38.856400 WARN : Plugin script reader: Could not find plugin file /opt/firmware/plugins/zwave/scripts/model/devices/monitoring/634_257_13.lua
2020-03-13 14:57:38.857657 WARN : Plugin script reader: Could not find plugin file /opt/firmware/plugins/zwave/scripts/model/devices/monitoring/generated/634_257_13.lua
2020-03-13 14:57:38.858637 WARN : Plugin script reader: Could not find plugin file /opt/firmware/plugins/zwave/scripts/model/devices/monitoring/.lua
2020-03-13 14:57:38.876120 INFO : LuaAddon: a script: HUB:zwave/scripts/events/events_handling has been executed successfully
Thank you @blacey for this detailed answer you provided so fast. Have you applied for Atom v2 beta yet?:slight_smile: We would like to have you also here :wink: Beta enrollment opened for Ezlo Atom v2
I’ll double check on that!
thanks for confirming that power usage reporting is up also in your case like @reneboer. I will look also into these warnings.
Yes, I applied yesterday :slightly_smiling_face:
I have successfully upgraded but the unit’s Wi-Fi is on. I would like to turn it off, but none of the command line methods work. Can you provide guidance?
I would like to suggest some essential functions missing from the current Ezlo firmware before it can be more than a hobby level controller (sorry, harsh but true).
  1. ability to set z-wave device associations
  2. ability to set z-wave device parameters
1 is core functionality imo. If I have a switch device (Aotec Mote something, Nodon Octan, etc) or a sensor i need to be able to set a direct association between that and a z-wave actor (switch, alarm, etc). I cannot have the controller as a single point of failure in these scenarios.
2 is needed to build a reliable z-wave network of any scale and to add new devices that may need a tweak. A known problem with several reporting devices is that they send way too many reports in the default config. For example an Aotec HEM will send 3 reports per second out of the box. Use two of those and you are done. Changing some devices bad behavior is a must.
I could make this list much longer, but this are two that are too important not to have. It should be up to par with the Vera capabilities before I would even consider it, but then reliable.
Cheers Rene
Hi @reneboer.
On the firmware level these functions are available.
Also we already have support for these functions in Lua.
Now we are working on API extension which will make it available in hub API.
I agree and I’de add the ability to display z-wave device details (e.g. firmware, etc.) akin to what is available in the Vera today.
@Ioana, FYI, I noticed a spread toolkit security warning in the logs a couple firmware versions ago and it is still there. Just raising awareness because it is a security issue that is easy to fix.
Conf_load_conf_file: using file: /etc/spread.conf
Successfully configured Segment 0 [127.0.0.255:4803] with 1 procs:
	           localhost: 127.0.0.1
ENABLING Dangerous Monitor Commands! Make sure Spread network is secured
Set runtime directory to '/var/run/spread'
Set user name to 'root'
Set group name to 'root'
Finished configuration file.
Hash value for this configuration is: 3871598377
Conf_load_conf_file: My name: localhost, id: 127.0.0.1, port: 4803
Spread: SECURITY RISK! running as root, but unix domain socket is not in a root-only writable directory. May risk denial of service or malicious deletion of unexpected file in directory: /tmp
Hangup
The root cause for the “SECURITY RISK!” seems to be a missing spread directive to set the spread runtime directory properly. As a test, I added the following to /etc/spread.conf and it suppresses the security warning.
RuntimeDir = /var/run/spread
And sent a HUP signal to the spread process to reload the config.
Spread daemon exiting normally!
Anyway, something small and easy to add to the backlog. Because it presents a security vulnerability and easily remedied, it behooves you guys to fix it sooner than later.
Another thought, as the team looks to secure spread, it might be productive to create a spread user and group and run the spread daemon as that user and group - you can configure the daemon user and group in /etc/spread.conf. Running a communications daemon with root privileges is unnecessary and in terms of security, considered bad form.
Food for thought.
@Ioana, just a followup on running the spread daemon under a non-root user and the unprotected 4803 socket.
  1. As a quick test, I added a spread user and group to /etc/passwd and /etc/group respectively and added DaemonUser = spread and DaemonGroup = spread to /etc/spread.config. I changed the owner of /var/firmware/log/spread.log to spread. For reference, here are the specific changes that I made:
/etc/passwd
root:x:0:0:root:/root:/bin/ash
daemon:*:1:1:daemon:/var:/bin/false
ftp:*:55:55:ftp:/home/ftp:/bin/false
network:*:101:101:network:/var:/bin/false
nobody:*:65534:65534:nobody:/var:/bin/false
spread:*:1111:1111:spread:/var:/bin/false
/etc/group
root:x:0:
daemon:x:1:
adm:x:4:
mail:x:8:
audio:x:29:
www-data:x:33:
ftp:x:55:
users:x:100:
network:x:101:
nogroup:x:65534:
spread:x:1111:
/etc/spread.conf
DaemonUser = spread
>>AFTER RESTART<<
Set user name to 'spread'
Set group name to 'spread'
ps w | grep spread | grep -v spread
 6786 spread    2888 S    /usr/sbin/spread -c /etc/spread.conf
Voila! Spread is no longer running as root.
  1. BUT!!! The SECURITY RISK message is back!!
I downloaded the spread toolkit source code and reviewed the configure options for a potential root cause for the spread sockets being opened in /tmp regardless of the RuntimeDir setting. I believe that the firmware build system sets the spread configure option --with-unix-socket-dir=/tmp which isn’t the best. It would be better to set it to /var/run/spread
root@8775fe673d9d:/tmp/spread-src-4.4.1# ./configure --help=short
Configuration of Spread 4.4.0:
Optional Packages:
  --with-PACKAGE[=ARG]    use PACKAGE [ARG=yes]
  --without-PACKAGE       do not use PACKAGE (same as --with-PACKAGE=no)
  --with-cflags           Specify additional flags to pass to compiler
  --with-cppflags         Specify additional flags to pass to preprocessor
  --with-ldflags          Specify additional flags to pass to linker
  --with-libs             Specify additional libraries to link with
  --with-mantype=man|cat|doc  Set man page type
  --with-pid-dir=PATH     Specify location of spread.pid file
  --with-unix-socket-dir=PATH     Specify location of Unix Domain Socket for client-daemon connections. If you are running Spread as a root user, you should define this to be a root only directory such as /var/run to avoid some security risks.
Finally, the team probably wants to update spread to version 4.1.4 vs. the current Linux firmware version 4.0.4 from May 2014.
Spread Security Recommendations:
  1. Configure spread build options to use /var/run/spread as the backing store for spread sockets
  2. Run spread under spread user and group (i.e. non-root). This entails adding a spread user and group id, modifying /etc/spread.conf to use them, and adjusting any permissions set by scripts like /opt/bin/firmware/spread.sh and /etc/init.d/spread to the spread user.
  3. Optional: upgrade spread 4.0.4 to 4.1.4
Doing these two pretty trivial development tasks should address the spread security issues. I realize this is alpha software but security is paramount for any device connected to the Internet and sometimes is more difficult to fix security issues later in the release cycle.
Thank you @blacey for reporting this, the team is looking into it and have it planned to work in the current sprint.
@blacey.
Hi blacey.
Thanks for your comment.
Spread security issue in our backlog.
It wiil be available in next releases.
Thanks.
FYI, I upgraded to 1.0.17 but spread it is still running with root privileges in the current version.
