Hi there,
I just got a Kerui Door Sensor that is not recognised.
It’s using Lighting4 subtype PT2262.
Would it be possible to add it?
Here are the log messages I got when using it :
Door open :
02 12/13/16 11:57:59.210 luup_log:11: RFXtrx: warning: Decoding not yet implemented for message 09 13 00 09 C9 E6 2E 01 40 70 <0x6edd9520>
Door closed :
02 12/13/16 12:00:07.268 luup_log:11: RFXtrx: warning: Decoding not yet implemented for message 09 13 00 0A C9 E6 27 01 40 70 <0x6edd9520>
Device tamper :
02 12/13/16 12:02:14.141 luup_log:11: RFXtrx: warning: Decoding not yet implemented for message 09 13 00 0B C9 E6 2B 01 3D 80 <0x6edd9520>
Hope it helps adding those new devices.
You can buy it here btw : https://goo.gl/RMjBTy
Thanks in advance!
Michel
So I flashed my rfxtrx433e in the latest EXT2 firmware release (1012) and it is recognised as X10 and immediately added
zazics
February 1, 2018, 1:52pm
#3
I also buy a Kerui door sensor on Aliexpress (5?)
[url=https://www.aliexpress.com/item/New-433mhz-Wireless-Door-window-Sensor-For-GSM-PSTN-Home-Alarm-System-Home-Security-Voice-Burglar/32285219054.html?spm=a2g0s.9042311.0.0.fFXBL8]https://www.aliexpress.com/item/New-433mhz-Wireless-Door-window-Sensor-For-GSM-PSTN-Home-Alarm-System-Home-Security-Voice-Burglar/32285219054.html?spm=a2g0s.9042311.0.0.fFXBL8[/url]
and successfully add it to my Vera Plus using RFXtrx433E, following this procedure and restart Vera (during procedure): [url=http://www.vesternet.com/resources/application-notes/apnt-116]http://www.vesternet.com/resources/application-notes/apnt-116[/url]
Then, I had to activate X10 and Lightning4 (only those one and disable others) protocols using “RFXmngr.exe”. That sensor only transmit “open status” but it’s enough.
