Hi
There seems to be a bug now with Colorloop effect not working properly and causing problems.
This seems to be a problem with my 3rd party Zigbee 3.0 LED controllers (Dresden fls-pp)
- Turn on the LED light strip
- Run a Vera scene to start the Colorloop effect
The colorloop starts and changes colours correctly as expected.
- Turn off the LED light strip
- Turn back on the LED light strip
- Attempt to change to different static colours using the AltHue devices colour picker.
You cannot then change any colours, using the colour picker in the UI7 interface it stops working.
I have to kill power supply to the actual LED controller and restore power before I can then change to different static colours again using the colour picker.
This is a newish problem and this did not happen before in the past.
If instead I use the Hue Labs colorloop and follow the same steps as above, I don’t see the problem, I can then after the colorloop, use the colour picker OK in UI7 to change to different static colours.
Its a very strange problem I am seeing.
https://labs.meethue.com/formulas/huelabs/colorloop
Thanks.
EDIT:
You have to set effect to “none” to stop the “colorloop”.
After doing that, I can then change to other static colours OK again.
