After several tests I was not able to trigger a mode change when venturing outside of my created fence.
One thing I have learned today is that I am not able to log into my VL with multiple clients at the same time. The prior version I was
open multiple clients on my phone and tablet and my laptop and see status or mode changes instantly on all of the other clients.
I also noticed that after creating my first geofence on my phone in the Vera app., it also appears on my tablet with the Vera app on it.
This begs the question, If I leave my tablet on at home will my Vera unit think I am at home?
I also learned there are 4 new options pertaining to the Geofence in UI7/Dashboards/My Modes/scroll to bottom.
The top two are delays in triggering modes and reporting tripped sensors.
“Wait 30 seconds before changing to any mode other than home.” (Why would you want to wait?)
“Wait 30 seconds before reporting a motion, door, window tripped” (I am not sure why you would want a delay in reporting tripped sensors if you were already away from the home.)
The next two are;
“Set house mode to HOME when at least one user is at home.” (If my geofence is on multiple GPS (mobile) devices, does that mean I have to take all of the devices I have the vera app installed out of the geofence to trigger the away mode?)
“Set house mode to AWAY when nobody is at home.” (I assume you have to install the Vera app on all peoples mobile devices in the home for this to work correctly?)
How I set it up the geofence in Android.
I have my geofence set up as “Home” with a 100M radius and 100m accuracy location and the home box checked.
As 100m is the minimum for accuracy, I fail to see why a radius size is effective if it is less than 100m.
I did not want the home to go to away mode if I was home, so I made it pretty big.
How I set up the the geofence in UI7
In UI7 I have 0 set for delays and neither option checked as described above.
What happens when I tested it.
Whether the app is running or not, if I go out of my created (Home) geofence (about 300 feet away from my home, so it is pretty accurate), my phone will vibrate and I get Android notification that says “Home Exit”.
When I re enter my fence I get a vibration and a notification that says “Home Enter”
Unfortunately neither of these actions trigger any mode change on my VL. I then opened the Vera app and could see no mode change.
I verified this with having one of my lights go on when the Away mode is triggered and off with home and I could then view it on an internal camera, then double checked with a call to my someone in the home.
The phone was registering the fence location change and showing a notification but apparently it was not triggering a mode change in my VL.
I still do not understand what mode is changed when, with the home option checked, or what mode is changed when I create a different geofence.
There is a “Home” check box that you can enable when creating a geo fence and I can only assume my system will change from home to away when going from in to out of my geofence, but this is a guess as there is no explanation as to how this works. If this the case, this begs the question, as to how and why I would need another geofence and what would it trigger.
Anyone else mess with this yet?
