£48.31 20%OFF | Full set Casement Actuator Window Sliding Arm Opener with Remote Control, DC24V Receiver, WIFI Switch y Rain Sensor Optional https://a.aliexpress.com/_uu02Sl
I’ve not used Broadlink myself as I have Harmony hubs and no RF 433 devices.
But I know lots of people use Broadlink RM Pros.
The bad with RF 433 is no feedback status from the devices as they are just dumb devices, so you can’t query their state.
I guess in this example you could use RF locally to operate the motor actuator and then use maybe Node Red with the Tuya node to query the windows status from the Tuya cloud.
Or maybe these could be flashed with Tasmota firmware for local WiFi control.
The RFXtrx433XL Dual Transmitter is another option.
BTW I use both as I need the RFXCom to control Somfy Blinds and Awnings. The Broadlink is great for IR and most RF devices - it’s ridiculously cheap as well.
If you need feedback, I’d suggest using a Door sensor for Open/Closed confirmation.
I already use the rfxtrx433xl, but it isn’t supported on Ezlo so I’m looking for an alternative. Bad thing on Broadlink is that it doesn’t support Somfy.
Somfy or RFXtrx433xl?
RFXtrx433 was quite high on the wishlist that was created long time ago. You actually donated a Ezlo Plus to the current developer that maintains the Vera Plus plugin. I expect it to be used by many users.
The RFXtrx is a 433Mhz transceiver with a serial or Ethernet interface. I am the current maintainer of the plugin for this device and I requested an Ezlo hub to modify the current plugin to run the Ezlo hub but I didn’t get one.
The RFXtrx has been upgraded to RFXtrxXL,
The RFXtrx433XL is a Dual Band USB 433.92 & 433.42MHz Transceiver.
check RFXCom web page for further details.
There is a Vera Plug In however I didn’t use it. It’s that long ago that I don’t remember how I added it to Vera. Vesternet has a good write up on Installation.
