I’ve been on the lookout for the perfect app for my tablet to control Vera and other networked devices. My main requirement was to have custom layouts and support multiple protocols. The other apps I surveyed had basic grid layouts and basic buttons for scenes, etc. I came across an app called NetIO (http://netio.davideickhoff.de). It works on Andriod and IOS. It can support several generic protocols, so I use the http GET method to control scenes/devices and get variables (described here: http://wiki.micasaverde.com/index.php/Luup_Requests). It uses a web based application (that is best done from a computer) to design the UI layout, then can be downloaded to app on tablet or phone. It has nifty icons such as light bulbs and many others that make the layout for home automation very cool looking. So for example I have a section of the screen for music control with favorites and volume control. I have another section for lights with light bulb icons for on and off and another section for weather. This is all on 1 page of a Nexus 7.
Anyway, if you have similar requirements for a home automation app, check it out. It is a little more a pain to have to know the device# and variable names for the http request, but cut and paste makes it easier.
I have a Yamaha network enabled receiver and use the Yamaha plug in under Vera to control. With NetIO, it is possible to control the receiver directly via tcp with the Yamaha YNCA protocol. It is much easier to use Yamaha plug in though.
Favorites are like Net Radio stations, FM Radio station, and Pandora channels. So for example, I have a button which corresponds to a particular Pandora channel. The Yamaha receivers allow network control of just about everything.
