I recently purchased a new Netgear R7000 router to replace my existing WNDR3700. I must say that the wireless range and speeds improved significantly, but did run into one problem. It could take a very long time before the connected devices would get an IP(v4) address via DHCP (could be more than 1 minute). Quite annoying.
After some trial and error I found out that the problem only occurred when the Vera3 was connected to the network. Once I removed the Vera3 from the network, devices would get an IP address immediately via DHCP…
I logged a support case with Netgear (23406993) and made Wireshark traces that I provided to them. From the traces it is pretty clear what happens. Once a PC on the network asks for an IP address, the R7000 router will offer one and and immediately the Vera3 will respond with a DHCPNAK. This restarts the DHCP process on the R7000 and it will offer the same IP over and over. Only once the PC is able to respond faster with an ACK than the Vera3, the DHCP process is completed.
[code]No. Time Source Destination Protocol Length Info
1345 11.999778000 0.0.0.0 255.255.255.255 bootpc 358 DHCP Request - Transaction ID 0x698079d6
1346 11.999778000 0.0.0.0 255.255.255.255 bootpc 358 DHCP Request - Transaction ID 0x698079d6
1347 12.010544000 192.168.1.175 255.255.255.255 bootps 342 DHCP NAK - Transaction ID 0x698079d6
1348 12.010545000 192.168.1.175 255.255.255.255 bootps 342 DHCP NAK - Transaction ID 0x698079d6
1355 12.018680000 0.0.0.0 255.255.255.255 bootpc 342 DHCP Discover - Transaction ID 0xd736ca59
1356 12.018680000 0.0.0.0 255.255.255.255 bootpc 342 DHCP Discover - Transaction ID 0xd736ca59
1382 12.068509000 192.168.1.1 192.168.1.114 bootps 590 DHCP ACK - Transaction ID 0x698079d6
1400 12.348495000 192.168.1.1 192.168.1.114 bootps 590 DHCP Offer - Transaction ID 0xd736ca59
1401 12.349091000 0.0.0.0 255.255.255.255 bootpc 364 DHCP Request - Transaction ID 0xd736ca59
1402 12.349092000 0.0.0.0 255.255.255.255 bootpc 364 DHCP Request - Transaction ID 0xd736ca59
1405 12.370342000 192.168.1.175 255.255.255.255 bootps 342 DHCP NAK - Transaction ID 0xd736ca59
1406 12.370344000 192.168.1.175 255.255.255.255 bootps 342 DHCP NAK - Transaction ID 0xd736ca59
1407 12.376464000 0.0.0.0 255.255.255.255 bootpc 342 DHCP Discover - Transaction ID 0xf9853216
1408 12.376467000 0.0.0.0 255.255.255.255 bootpc 342 DHCP Discover - Transaction ID 0xf9853216
1412 12.418512000 192.168.1.1 192.168.1.114 bootps 590 DHCP ACK - Transaction ID 0xd736ca59
1439 12.559131000 192.168.1.1 192.168.1.114 bootps 590 DHCP Offer - Transaction ID 0xf9853216
1440 12.566502000 0.0.0.0 255.255.255.255 bootpc 364 DHCP Request - Transaction ID 0xf9853216
1441 12.566505000 0.0.0.0 255.255.255.255 bootpc 364 DHCP Request - Transaction ID 0xf9853216
1443 12.580005000 192.168.1.175 255.255.255.255 bootps 342 DHCP NAK - Transaction ID 0xf9853216
1444 12.580006000 192.168.1.175 255.255.255.255 bootps 342 DHCP NAK - Transaction ID 0xf9853216
1445 12.591098000 0.0.0.0 255.255.255.255 bootpc 342 DHCP Discover - Transaction ID 0xb7926b5f
1446 12.591099000 0.0.0.0 255.255.255.255 bootpc 342 DHCP Discover - Transaction ID 0xb7926b5f
1448 12.618419000 192.168.1.1 192.168.1.114 bootps 590 DHCP ACK - Transaction ID 0xf9853216
1471 12.838508000 192.168.1.1 192.168.1.114 bootps 590 DHCP Offer - Transaction ID 0xb7926b5f
1472 12.839508000 0.0.0.0 255.255.255.255 bootpc 364 DHCP Request - Transaction ID 0xb7926b5f
1473 12.839510000 0.0.0.0 255.255.255.255 bootpc 364 DHCP Request - Transaction ID 0xb7926b5f
1483 12.880276000 192.168.1.175 255.255.255.255 bootps 342 DHCP NAK - Transaction ID 0xb7926b5f
1484 12.880282000 192.168.1.175 255.255.255.255 bootps 342 DHCP NAK - Transaction ID 0xb7926b5f
1485 12.885786000 0.0.0.0 255.255.255.255 bootpc 342 DHCP Discover - Transaction ID 0x8f271068
1486 12.885788000 0.0.0.0 255.255.255.255 bootpc 342 DHCP Discover - Transaction ID 0x8f271068
1488 12.928485000 192.168.1.1 192.168.1.114 bootps 590 DHCP ACK - Transaction ID 0xb7926b5f
1508 13.088451000 192.168.1.1 192.168.1.114 bootps 590 DHCP Offer - Transaction ID 0x8f271068
1509 13.088800000 0.0.0.0 255.255.255.255 bootpc 364 DHCP Request - Transaction ID 0x8f271068
1510 13.088801000 0.0.0.0 255.255.255.255 bootpc 364 DHCP Request - Transaction ID 0x8f271068
1512 13.110367000 192.168.1.175 255.255.255.255 bootps 342 DHCP NAK - Transaction ID 0x8f271068
1513 13.110369000 192.168.1.175 255.255.255.255 bootps 342 DHCP NAK - Transaction ID 0x8f271068
1514 13.115806000 0.0.0.0 255.255.255.255 bootpc 342 DHCP Discover - Transaction ID 0x98f7de64
1515 13.115808000 0.0.0.0 255.255.255.255 bootpc 342 DHCP Discover - Transaction ID 0x98f7de64
1518 13.168478000 192.168.1.1 192.168.1.114 bootps 590 DHCP ACK - Transaction ID 0x8f271068
1531 13.368479000 192.168.1.1 192.168.1.114 bootps 590 DHCP Offer - Transaction ID 0x98f7de64
1532 13.369377000 0.0.0.0 255.255.255.255 bootpc 364 DHCP Request - Transaction ID 0x98f7de64
1533 13.369378000 0.0.0.0 255.255.255.255 bootpc 364 DHCP Request - Transaction ID 0x98f7de64
1536 13.385110000 192.168.1.175 255.255.255.255 bootps 342 DHCP NAK - Transaction ID 0x98f7de64
1537 13.385112000 192.168.1.175 255.255.255.255 bootps 342 DHCP NAK - Transaction ID 0x98f7de64
1538 13.390502000 0.0.0.0 255.255.255.255 bootpc 342 DHCP Discover - Transaction ID 0x511a78f8
1539 13.390504000 0.0.0.0 255.255.255.255 bootpc 342 DHCP Discover - Transaction ID 0x511a78f8
1545 13.459142000 192.168.1.1 192.168.1.114 bootps 590 DHCP ACK - Transaction ID 0x98f7de64
1559 13.588471000 192.168.1.1 192.168.1.114 bootps 590 DHCP Offer - Transaction ID 0x511a78f8
1560 13.589799000 0.0.0.0 255.255.255.255 bootpc 364 DHCP Request - Transaction ID 0x511a78f8
1561 13.589800000 0.0.0.0 255.255.255.255 bootpc 364 DHCP Request - Transaction ID 0x511a78f8
1563 13.616183000 192.168.1.175 255.255.255.255 bootps 342 DHCP NAK - Transaction ID 0x511a78f8
1564 13.616184000 192.168.1.175 255.255.255.255 bootps 342 DHCP NAK - Transaction ID 0x511a78f8
1565 13.620823000 0.0.0.0 255.255.255.255 bootpc 342 DHCP Discover - Transaction ID 0xcce184ba
1566 13.620824000 0.0.0.0 255.255.255.255 bootpc 342 DHCP Discover - Transaction ID 0xcce184ba
1570 13.678458000 192.168.1.1 192.168.1.114 bootps 590 DHCP ACK - Transaction ID 0x511a78f8
1789 14.018423000 192.168.1.1 192.168.1.114 bootps 590 DHCP Offer - Transaction ID 0xcce184ba
1790 14.019471000 0.0.0.0 255.255.255.255 bootpc 364 DHCP Request - Transaction ID 0xcce184ba
1791 14.019471000 0.0.0.0 255.255.255.255 bootpc 364 DHCP Request - Transaction ID 0xcce184ba
1792 14.039960000 192.168.1.175 255.255.255.255 bootps 342 DHCP NAK - Transaction ID 0xcce184ba
1793 14.039961000 192.168.1.175 255.255.255.255 bootps 342 DHCP NAK - Transaction ID 0xcce184ba
1796 14.050041000 0.0.0.0 255.255.255.255 bootpc 342 DHCP Discover - Transaction ID 0xf57071e9
1797 14.050042000 0.0.0.0 255.255.255.255 bootpc 342 DHCP Discover - Transaction ID 0xf57071e9
1801 14.138450000 192.168.1.1 192.168.1.114 bootps 590 DHCP ACK - Transaction ID 0xcce184ba
1814 14.300199000 192.168.1.1 192.168.1.114 bootps 590 DHCP Offer - Transaction ID 0xf57071e9
1815 14.301087000 0.0.0.0 255.255.255.255 bootpc 364 DHCP Request - Transaction ID 0xf57071e9
1816 14.301091000 0.0.0.0 255.255.255.255 bootpc 364 DHCP Request - Transaction ID 0xf57071e9
1817 14.311365000 192.168.1.175 255.255.255.255 bootps 342 DHCP NAK - Transaction ID 0xf57071e9
1818 14.311367000 192.168.1.175 255.255.255.255 bootps 342 DHCP NAK - Transaction ID 0xf57071e9
1821 14.316712000 0.0.0.0 255.255.255.255 bootpc 342 DHCP Discover - Transaction ID 0x62f114c0
1822 14.316714000 0.0.0.0 255.255.255.255 bootpc 342 DHCP Discover - Transaction ID 0x62f114c0
1826 14.389319000 192.168.1.1 192.168.1.114 bootps 590 DHCP ACK - Transaction ID 0xf57071e9
1853 14.539083000 192.168.1.1 192.168.1.114 bootps 590 DHCP Offer - Transaction ID 0x62f114c0
1857 14.539833000 0.0.0.0 255.255.255.255 bootpc 364 DHCP Request - Transaction ID 0x62f114c0
1858 14.539835000 0.0.0.0 255.255.255.255 bootpc 364 DHCP Request - Transaction ID 0x62f114c0
1868 14.563014000 192.168.1.175 255.255.255.255 bootps 342 DHCP NAK - Transaction ID 0x62f114c0
1869 14.563018000 192.168.1.175 255.255.255.255 bootps 342 DHCP NAK - Transaction ID 0x62f114c0
1870 14.566950000 0.0.0.0 255.255.255.255 bootpc 342 DHCP Discover - Transaction ID 0xb8fcbb3f
1871 14.566951000 0.0.0.0 255.255.255.255 bootpc 342 DHCP Discover - Transaction ID 0xb8fcbb3f
1882 14.618422000 192.168.1.1 192.168.1.114 bootps 590 DHCP ACK - Transaction ID 0x62f114c0
1898 14.779087000 192.168.1.1 192.168.1.114 bootps 590 DHCP Offer - Transaction ID 0xb8fcbb3f
1900 14.782625000 0.0.0.0 255.255.255.255 bootpc 364 DHCP Request - Transaction ID 0xb8fcbb3f
1901 14.782626000 0.0.0.0 255.255.255.255 bootpc 364 DHCP Request - Transaction ID 0xb8fcbb3f
1902 14.790027000 192.168.1.175 255.255.255.255 bootps 342 DHCP NAK - Transaction ID 0xb8fcbb3f
1903 14.790028000 192.168.1.175 255.255.255.255 bootps 342 DHCP NAK - Transaction ID 0xb8fcbb3f
1904 14.793336000 0.0.0.0 255.255.255.255 bootpc 342 DHCP Discover - Transaction ID 0x81705649
1905 14.793338000 0.0.0.0 255.255.255.255 bootpc 342 DHCP Discover - Transaction ID 0x81705649
1908 14.872575000 192.168.1.1 192.168.1.114 bootps 590 DHCP ACK - Transaction ID 0xb8fcbb3f
1943 15.078499000 192.168.1.1 192.168.1.114 bootps 590 DHCP Offer - Transaction ID 0x81705649
1944 15.079439000 0.0.0.0 255.255.255.255 bootpc 364 DHCP Request - Transaction ID 0x81705649
1945 15.079441000 0.0.0.0 255.255.255.255 bootpc 364 DHCP Request - Transaction ID 0x81705649
1948 15.099595000 192.168.1.175 255.255.255.255 bootps 342 DHCP NAK - Transaction ID 0x81705649
1949 15.099602000 192.168.1.175 255.255.255.255 bootps 342 DHCP NAK - Transaction ID 0x81705649
1950 15.105061000 0.0.0.0 255.255.255.255 bootpc 342 DHCP Discover - Transaction ID 0x38e5bd3d
1951 15.105062000 0.0.0.0 255.255.255.255 bootpc 342 DHCP Discover - Transaction ID 0x38e5bd3d
1952 15.159094000 192.168.1.1 192.168.1.114 bootps 590 DHCP ACK - Transaction ID 0x81705649
1989 15.569062000 192.168.1.1 192.168.1.114 bootps 590 DHCP Offer - Transaction ID 0x38e5bd3d
1990 15.569799000 0.0.0.0 255.255.255.255 bootpc 364 DHCP Request - Transaction ID 0x38e5bd3d
1991 15.569800000 0.0.0.0 255.255.255.255 bootpc 364 DHCP Request - Transaction ID 0x38e5bd3d
1992 15.580756000 192.168.1.175 255.255.255.255 bootps 342 DHCP NAK - Transaction ID 0x38e5bd3d
1993 15.580758000 192.168.1.175 255.255.255.255 bootps 342 DHCP NAK - Transaction ID 0x38e5bd3d
1995 15.585750000 0.0.0.0 255.255.255.255 bootpc 342 DHCP Discover - Transaction ID 0x86836216
1996 15.585751000 0.0.0.0 255.255.255.255 bootpc 342 DHCP Discover - Transaction ID 0x86836216
2002 15.638456000 192.168.1.1 192.168.1.114 bootps 590 DHCP ACK - Transaction ID 0x38e5bd3d
2056 16.091263000 192.168.1.1 192.168.1.114 bootps 590 DHCP Offer - Transaction ID 0x86836216
2057 16.091875000 0.0.0.0 255.255.255.255 bootpc 364 DHCP Request - Transaction ID 0x86836216
2058 16.091877000 0.0.0.0 255.255.255.255 bootpc 364 DHCP Request - Transaction ID 0x86836216
2060 16.102080000 192.168.1.175 255.255.255.255 bootps 342 DHCP NAK - Transaction ID 0x86836216
2061 16.102082000 192.168.1.175 255.255.255.255 bootps 342 DHCP NAK - Transaction ID 0x86836216
2063 16.107434000 0.0.0.0 255.255.255.255 bootpc 342 DHCP Discover - Transaction ID 0x7affe238
2064 16.107435000 0.0.0.0 255.255.255.255 bootpc 342 DHCP Discover - Transaction ID 0x7affe238
2065 16.168464000 192.168.1.1 192.168.1.114 bootps 590 DHCP ACK - Transaction ID 0x86836216
2080 16.389430000 192.168.1.1 192.168.1.114 bootps 590 DHCP Offer - Transaction ID 0x7affe238
2081 16.389432000 0.0.0.0 255.255.255.255 bootpc 364 DHCP Request - Transaction ID 0x7affe238
2082 16.389433000 0.0.0.0 255.255.255.255 bootpc 364 DHCP Request - Transaction ID 0x7affe238
2084 16.399748000 192.168.1.175 255.255.255.255 bootps 342 DHCP NAK - Transaction ID 0x7affe238
2085 16.399749000 192.168.1.175 255.255.255.255 bootps 342 DHCP NAK - Transaction ID 0x7affe238
2086 16.401508000 0.0.0.0 255.255.255.255 bootpc 342 DHCP Discover - Transaction ID 0xa45f7e2c
2087 16.401509000 0.0.0.0 255.255.255.255 bootpc 342 DHCP Discover - Transaction ID 0xa45f7e2c
2094 16.478494000 192.168.1.1 192.168.1.114 bootps 590 DHCP ACK - Transaction ID 0x7affe238
2114 16.628487000 192.168.1.1 192.168.1.114 bootps 590 DHCP Offer - Transaction ID 0xa45f7e2c
2115 16.630737000 0.0.0.0 255.255.255.255 bootpc 364 DHCP Request - Transaction ID 0xa45f7e2c
2116 16.630739000 0.0.0.0 255.255.255.255 bootpc 364 DHCP Request - Transaction ID 0xa45f7e2c
2123 16.650234000 192.168.1.175 255.255.255.255 bootps 342 DHCP NAK - Transaction ID 0xa45f7e2c
2124 16.650236000 192.168.1.175 255.255.255.255 bootps 342 DHCP NAK - Transaction ID 0xa45f7e2c
2125 16.656456000 0.0.0.0 255.255.255.255 bootpc 342 DHCP Discover - Transaction ID 0xd70cb320
2126 16.656458000 0.0.0.0 255.255.255.255 bootpc 342 DHCP Discover - Transaction ID 0xd70cb320
2130 16.739035000 192.168.1.1 192.168.1.114 bootps 590 DHCP ACK - Transaction ID 0xa45f7e2c
8472 55.798282000 192.168.1.1 192.168.1.114 bootps 590 DHCP Offer - Transaction ID 0x617fc852
8473 55.799359000 0.0.0.0 255.255.255.255 bootpc 364 DHCP Request - Transaction ID 0x617fc852
8474 55.799360000 0.0.0.0 255.255.255.255 bootpc 364 DHCP Request - Transaction ID 0x617fc852
8475 55.810115000 192.168.1.175 255.255.255.255 bootps 342 DHCP NAK - Transaction ID 0x617fc852
8476 55.810118000 192.168.1.175 255.255.255.255 bootps 342 DHCP NAK - Transaction ID 0x617fc852
8478 55.815589000 0.0.0.0 255.255.255.255 bootpc 342 DHCP Discover - Transaction ID 0xdc000cfb
8479 55.815591000 0.0.0.0 255.255.255.255 bootpc 342 DHCP Discover - Transaction ID 0xdc000cfb
8481 55.878280000 192.168.1.1 192.168.1.114 bootps 590 DHCP ACK - Transaction ID 0x617fc852
8486 56.028498000 192.168.1.1 192.168.1.114 bootps 590 DHCP Offer - Transaction ID 0xdc000cfb
8487 56.048158000 0.0.0.0 255.255.255.255 bootpc 364 DHCP Request - Transaction ID 0xdc000cfb
8488 56.048160000 0.0.0.0 255.255.255.255 bootpc 364 DHCP Request - Transaction ID 0xdc000cfb
8493 56.151753000 192.168.1.1 192.168.1.114 bootps 590 DHCP ACK - Transaction ID 0xdc000cfb
8503 56.178153000 192.168.1.175 255.255.255.255 bootps 342 DHCP NAK - Transaction ID 0xdc000cfb
8504 56.178153000 192.168.1.175 255.255.255.255 bootps 342 DHCP NAK - Transaction ID 0xdc000cfb
[/code]
The part that the Vera3 responds with a NAK is really strange (and faulty), as the Vera3 is connected to the network via the WAN port. It turns out that the Vera3 DHCP process for the LAN ports is also interfering on the WAN port. Disabling the DHCP server on the Vera3 clears the issue.
However, I believe the Netgear R7000 DHCP process is also faulty, as it restarts the DHCP process after a DHCPNAK (which is a server response - and in this case the R7000 is a server; it should only process client responses). My previous Netgear WNDR3700 also did not have a problem with the Vera3 behavior.
Today Netgear support has let me know that they will not fix the issues, as they state the Vera3 is at fault.
Question: is anybody else using the same combination (or a different router) and experiencing the same issue?
