If you change the device_json attribute of any of the incorrectly badged sensor devices from D_Netatmo.json to D_NetatmoMetric.json, does that fix the icon for that sensor?
AK,
I just got a Netatmo weather station and I was wondering what the best way to install the app would be? When I go to Install Apps in my VP the app shows:
Updated:2018-07-06 23:51:18
Current Version:18.227
Do I wait for Vera to approve and update or can I install this version then manually copy the updated files from the development branch in github?
Thank you in advance.
Regards,
Tim
Thanks. I have not tried AltUI. My time spent so far with Vera has been frustrating to say the least and I did not want to add an additional variable to the equation.
IMHO there is no reason not to use the current store version, the only part of it that doesn’t work ootb are the custom icons which AK has described the, very easy, fix for in recent replies to me on this topic.
@akbooer Just wondering if netatmo allow us to access their forecast info via the API? Having this in addition to our own live weather data would be the icing on the cake.
Looks like Vera updated the app so I tried installing but its showing
Luup:Failed to download all plugins will retry in 10 minutes
Netatmo:Lua Error
Have tried several engine reloads still failing
