I am not sure if it is correct place to post this topic, did anyone played with Netatmo weather station plugin offered by Vera (the one which you install from the “Devices > Thermostats” section)?
It has some nice functionalities like choosing specific station if you have more than one of them, and access to the history of measurements.
But I have some difficulties with it:
First, the devices which it creates present only temp. reading. To see other readings, you need to go into Device, and then Measures tab. Is it possible to create other child devices for various readings? If yes, how to do it?
Second, I can’t attach wind meter to it. It is not visible as a device nor in any of Measures sections for devices which were created. Did anyone try it with success?
