Netatmo, username and password?
[quote=“jswim788, post:9, topic:199166”]Can you see it in the variable list?
http://vera_IP:3480/data_request?id=status&output_format=xml&DeviceNum=39(replace ‘39’ with your device ID and use the proper Vera IP).
Also, it is possible to go to the advanced tab and create the variables if they aren’t there. I believe you’d want to use the NetatmoSID:urn:akbooer-com:serviceId:Netatmo1[/quote]
Yes I can see the username and password in the variable list.
I manually created the variables and values and it now all works ok ;D. But can still not see them in the advance tab. Not an issue for now as I should not need to change the values.
Thanks for your help.
