Ive installed the Netatmo app and can enter the ClientID and ClientSecret. I also have my Netatmo username and password to enter but there is nowhere to enter username and password? See attached image. What am I doing wrong?
I’m new to Vera and my skill level is basic, sorry.
Pete
try restarting you Vera and then refreshing your browser (Ctrl + F5).
Have tried restarting and refreshing many times and no change.
Then I guess you need to try to install the plugin again, seems like something is missing.
Try grabbing the latest files from github → https://github.com/akbooer/Netatmo/tree/development
I, too, have the same defect.
Yesterday, in the area of 10 GМT, communication with the weather station was lost.
I also checked the settings. There is no space for entering the password.
I was helped by a reboot, it all worked.
BUT! place did not appear
Just a thought - are they getting populated under the Params tab instead of Variables? Even the older 2016 code does seem to set the default username and password variables to ???.
[quote=“korttoma, post:4, topic:199166”]Then I guess you need to try to install the plugin again, seems like something is missing.
Try grabbing the latest files from github → https://github.com/akbooer/Netatmo/tree/development[/quote]
I have installed these latest files and issue is still present.
Can you see it in the variable list?
http://vera_IP:3480/data_request?id=status&output_format=xml&DeviceNum=39(replace ‘39’ with your device ID and use the proper Vera IP).
Also, it is possible to go to the advanced tab and create the variables if they aren’t there. I believe you’d want to use the NetatmoSID:urn:akbooer-com:serviceId:Netatmo1
[quote=“jswim788, post:9, topic:199166”]Can you see it in the variable list?
Also, it is possible to go to the advanced tab and create the variables if they aren’t there. I believe you’d want to use the NetatmoSID:urn:akbooer-com:serviceId:Netatmo1[/quote]
Yes I can see the username and password in the variable list.
I manually created the variables and values and it now all works ok ;D. But can still not see them in the advance tab. Not an issue for now as I should not need to change the values.
Thanks for your help.
[quote=“peterpercy, post:10, topic:199166”]Yes I can see the username and password in the variable list.
I manually created the variables and values and it now all works ok ;D. But can still not see them in the advance tab. Not an issue for now as I should not need to change the values.[/quote]Perhaps this is a “feature”. Maybe the Vera is hiding these variables as a security precaution even though they are visible through other means.
HI NOVICE IN PROGRAMMING I DO NOT KNOW HOW TO MAKE MANUALLY CREATED MANUALLY CREATED THE variables AND VALUES AND VALUES J AI THE SAME PROBLEM AS ABOVE THANK YOU FOR YOUR SUPPORT A +
Type this into the UI page at Apps > Develop apps > TestLuup code (Lua)
luup.variable_set ("urn:akbooer-com:serviceId:Netatmo1", "Username", "XXX", DDD)
luup.variable_set ("urn:akbooer-com:serviceId:Netatmo1", "Password", "YYY", DDD)
where:
[ul][li]DDD - is the device number of your Netatmo plugin[/li]
[li]XXX - is your Netatmo account username[/li]
[li]YYY - is your Netatmo account password (avoid special characters)[/li][/ul]
then press GO.
thank you for the answer I will try to get to know you
:)ok all works thanks for the information
[quote=“akbooer, post:13, topic:199166”]Type this into the UI page at Apps > Develop apps > TestLuup code (Lua)
where:
then press GO.[/quote]
We have the same problem with Blue Iris… can not set the Username and the Password anymore… Do you have any idea what could be the command for Blue Iris…
