Netatmo no longer working on vera plus 'Authorisaton Failed'
For some reason Netatmo is failing on my Vera plus controller. Getting ’ Authorisation failed’ error but I can login fine on the Netatmo website and the Netatmo app on my phone works fine.
Any help is greatly appreciated.
I downloaded the latest app from GitHub, reauthorized and it’s working again.
Hi!
We are glad to know that is working again! Have a nice one!
Netatmo app is reporting not authorized and when I try and authorize I get the following error:
Error: Failed to retrieve access token using authorization code
Is anyone else seeing an error? Anyone know if akbooer still frequents the forum?
I have same error. Its been there for 2-3 weeks. Anyone know how to fix it?
Apparently this problem is related to a change that Netatmo made on their side.
This is from someone one another HA forum.
“I just received an email from Netatmo that they will update their policy regarding API keys and Access/Refresh Tokens as per May 29, 2024.”
The author of the plugin is aware but as you can see from the Netatmo help center there seems to be some confusion with the tokens.
So most likely we’ll need to wait for a patch for the plugin.
I’d be curious to try it on my Ezlo controller but when I try and add the Netatmo weather station it errors.
I was able to get this working.
What’s interesting is I tried logging on to http://dev.netatmo.com and it redirected me to http://home.netatmo.com so it seems that the dev account that I had created is no longer necessary as I can not access it any longer. After the redirect I went to the partner apps section under my account ( ‘Settings\My Account\Partner Apps’) and noticed there were several entries for ‘OpenLuup’ so what I did was remove the oldest entry and it removed all the entries.
After removing the entries I went back to the Netatmo app in my Vera controller and clicked authorize again and this time the device came back on line and is responding again.
Same here, thanks, your work around helped
Hello, How can I download the latest version of the GitHub application?
Looks like there are issues connecting/authorizing again.
Anyone else receiving the authorization errors and getting an error when they try and reauthorize?
Yes same error here, any solution?
Unfortunately no. AK has moved away from Netamo but was nice enough to take a look at it and is uncertain as to what is happening.
Thanks to AK for taking a look at this.
