Netatmo Newbie Question *** What do I do with These Files ***
Hello All:
Can someone point me to a an exsisiting post, or give me some instruction on what to do with the files I downloaded from the latest Netatmo post. I get a Zip file with folders _MACOSX, icons, json,xml, XML document, Lua File, Lua File 2.
I am not sure what to do with them to get my UI7 working with my Netatmo.
Thanks,
Joe-
the macosx folder you can delete. The .json .xml and .lua files should be uploaded to your Vera. I am not using UI7 but there should be a page available somewhere under apps develoupe apps and lua files or something similar.
Use the zip archive from here -> http://forum.micasaverde.com/index.php/topic,30478.msg247304.html#msg247304
Then follow the instruktions from here i think -> http://forum.micasaverde.com/index.php/topic,16276.0.html
