Nest / VeraConnectWWN issue
Hi !
I had a very stable setup for the last month so I tough it was a good time the mess around and break everything :slight_smile:
So for the last month I’ve monitored carefully my logs (luaupnp.log) and made sure I got a notification everytime the engine restart. And that happened rarely more than once a day and that was fine.
So I reconnect my Nest module with the Vera. That was really straight forward and worked right away… but then after that, I start noticing that the luup engine began to restart almost once every hour… checking the log I can see that VeraConnectWWN is verbosing alot without any apparent error… Does anyone knows how I can investigate a bit more ? is there anything I can do ?
Here is a sample of what it looks like :
50 06/01/17 12:10:09.365 luup_log:135: VeraConnectWWN::appendDevices> Append thermostat: Downstairs (Salle ? manger) <0x7689f520>
50 06/01/17 12:10:09.366 luup_log:135: VeraConnectWWN::appendDevices> Append humidity sensor: Downstairs (Salle ? manger) <0x7689f520>
50 06/01/17 12:10:09.366 luup_log:135: VeraConnectWWN::appendDevices> Append Home/Away: Maison <0x7689f520>
50 06/01/17 12:10:09.396 luup_log:135: VeraConnectWWN::getNestStreamPids> Got output: 19093
50 06/01/17 12:10:09.397 luup_log:135: VeraConnectWWN::isStreaming> Streaming: true <0x7689f520>
50 06/01/17 12:10:09.397 luup_log:135: VeraConnectWWN::Startup> Startup successful <0x7689f520>
01 06/01/17 12:10:09.398 LuaInterface::CallFunction_Startup device 135 function VeraConnectWWNStartup took 8 seconds <0x7689f520>
50 06/01/17 12:10:09.409 luup_log:136: VeraConnectWWNDeauth> VeraConnectWWN Deauthorization Plugin rev 5 <0x7689f520>
50 06/01/17 12:10:09.409 luup_log:136: VeraConnectWWNDeauth> Remove the deathorization code from StartupCode <0x7689f520>
50 06/01/17 12:10:09.418 luup_log:136: VeraConnectWWNDeauth> Found Nest device: 135 <0x7689f520>
50 06/01/17 12:10:09.419 luup_log:136: VeraConnectWWNDeauth> Save the Nest token <0x7689f520>
50 06/01/17 12:10:09.419 luup_log:136: VeraConnectWWNDeauth> Startup completed <0x7689f520>
50 06/01/17 12:10:19.129 luup_log:135: VeraConnectWWN::getNestStreamPids> Got output: 19093
50 06/01/17 12:10:19.129 luup_log:135: VeraConnectWWN::isStreaming> Streaming: true <0x74a9f520>
50 06/01/17 12:10:29.108 luup_log:135: VeraConnectWWN::getNestStreamPids> Got output: 19093
50 06/01/17 12:10:29.108 luup_log:135: VeraConnectWWN::isStreaming> Streaming: true <0x74a9f520>
50 06/01/17 12:10:39.129 luup_log:135: VeraConnectWWN::getNestStreamPids> Got output: 19093
50 06/01/17 12:10:39.130 luup_log:135: VeraConnectWWN::isStreaming> Streaming: true <0x74a9f520>
50 06/01/17 12:10:49.129 luup_log:135: VeraConnectWWN::getNestStreamPids> Got output: 19093
50 06/01/17 12:10:49.129 luup_log:135: VeraConnectWWN::isStreaming> Streaming: true <0x74a9f520>
50 06/01/17 12:10:59.129 luup_log:135: VeraConnectWWN::getNestStreamPids> Got output: 19093
50 06/01/17 12:10:59.129 luup_log:135: VeraConnectWWN::isStreaming> Streaming: true <0x74a9f520>
50 06/01/17 12:11:09.129 luup_log:135: VeraConnectWWN::getNestStreamPids> Got output: 19093
50 06/01/17 12:11:09.130 luup_log:135: VeraConnectWWN::isStreaming> Streaming: true <0x74a9f520>
50 06/01/17 12:11:19.129 luup_log:135: VeraConnectWWN::getNestStreamPids> Got output: 19093
50 06/01/17 12:11:19.129 luup_log:135: VeraConnectWWN::isStreaming> Streaming: true <0x74a9f520>
50 06/01/17 12:11:29.129 luup_log:135: VeraConnectWWN::getNestStreamPids> Got output: 19093
50 06/01/17 12:11:29.129 luup_log:135: VeraConnectWWN::isStreaming> Streaming: true <0x74a9f520>
50 06/01/17 12:11:39.129 luup_log:135: VeraConnectWWN::getNestStreamPids> Got output: 19093
50 06/01/17 12:11:39.130 luup_log:135: VeraConnectWWN::isStreaming> Streaming: true <0x74a9f520>
50 06/01/17 12:11:49.136 luup_log:135: VeraConnectWWN::getNestStreamPids> Got output: 19093
50 06/01/17 12:11:49.137 luup_log:135: VeraConnectWWN::isStreaming> Streaming: true <0x74a9f520>
50 06/01/17 12:11:59.129 luup_log:135: VeraConnectWWN::getNestStreamPids> Got output: 19093
50 06/01/17 12:11:59.129 luup_log:135: VeraConnectWWN::isStreaming> Streaming: true <0x74a9f520>
50 06/01/17 12:12:09.129 luup_log:135: VeraConnectWWN::getNestStreamPids> Got output: 19093
50 06/01/17 12:12:09.130 luup_log:135: VeraConnectWWN::isStreaming> Streaming: true <0x74a9f520>
50 06/01/17 12:12:19.129 luup_log:135: VeraConnectWWN::getNestStreamPids> Got output: 19093
50 06/01/17 12:12:19.129 luup_log:135: VeraConnectWWN::isStreaming> Streaming: true <0x74a9f520>
50 06/01/17 12:12:29.129 luup_log:135: VeraConnectWWN::getNestStreamPids> Got output: 19093
50 06/01/17 12:12:29.130 luup_log:135: VeraConnectWWN::isStreaming> Streaming: true <0x74a9f520>
50 06/01/17 12:12:39.129 luup_log:135: VeraConnectWWN::getNestStreamPids> Got output: 19093
50 06/01/17 12:12:39.130 luup_log:135: VeraConnectWWN::isStreaming> Streaming: true <0x74a9f520>
50 06/01/17 12:12:49.129 luup_log:135: VeraConnectWWN::getNestStreamPids> Got output: 19093
50 06/01/17 12:12:49.129 luup_log:135: VeraConnectWWN::isStreaming> Streaming: true <0x74a9f520>
50 06/01/17 12:12:59.129 luup_log:135: VeraConnectWWN::getNestStreamPids> Got output: 19093
50 06/01/17 12:12:59.130 luup_log:135: VeraConnectWWN::isStreaming> Streaming: true <0x74a9f520>
50 06/01/17 12:13:09.132 luup_log:135: VeraConnectWWN::getNestStreamPids> Got output: 19093
50 06/01/17 12:13:09.132 luup_log:135: VeraConnectWWN::isStreaming> Streaming: true <0x74a9f520>
50 06/01/17 12:13:19.129 luup_log:135: VeraConnectWWN::getNestStreamPids> Got output: 19093
50 06/01/17 12:13:19.129 luup_log:135: VeraConnectWWN::isStreaming> Streaming: true <0x74a9f520>
50 06/01/17 12:13:29.128 luup_log:135: VeraConnectWWN::getNestStreamPids> Got output: 19093
50 06/01/17 12:13:29.129 luup_log:135: VeraConnectWWN::isStreaming> Streaming: true <0x74a9f520>
50 06/01/17 12:13:39.129 luup_log:135: VeraConnectWWN::getNestStreamPids> Got output: 19093
50 06/01/17 12:13:39.130 luup_log:135: VeraConnectWWN::isStreaming> Streaming: true <0x74a9f520>
50 06/01/17 12:13:49.128 luup_log:135: VeraConnectWWN::getNestStreamPids> Got output: 19093
50 06/01/17 12:13:49.129 luup_log:135: VeraConnectWWN::isStreaming> Streaming: true <0x74a9f520>
50 06/01/17 12:13:59.129 luup_log:135: VeraConnectWWN::getNestStreamPids> Got output: 19093
50 06/01/17 12:13:59.129 luup_log:135: VeraConnectWWN::isStreaming> Streaming: true <0x74a9f520>
50 06/01/17 12:14:09.129 luup_log:135: VeraConnectWWN::getNestStreamPids> Got output: 19093
50 06/01/17 12:14:09.130 luup_log:135: VeraConnectWWN::isStreaming> Streaming: true <0x74a9f520>
50 06/01/17 12:14:19.129 luup_log:135: VeraConnectWWN::getNestStreamPids> Got output: 19093
50 06/01/17 12:14:19.129 luup_log:135: VeraConnectWWN::isStreaming> Streaming: true <0x74a9f520>
50 06/01/17 12:14:29.128 luup_log:135: VeraConnectWWN::getNestStreamPids> Got output: 19093
50 06/01/17 12:14:29.129 luup_log:135: VeraConnectWWN::isStreaming> Streaming: true <0x74a9f520>
50 06/01/17 12:14:39.141 luup_log:135: VeraConnectWWN::getNestStreamPids> Got output: 19093
50 06/01/17 12:14:39.141 luup_log:135: VeraConnectWWN::isStreaming> Streaming: true <0x74a9f520>
50 06/01/17 12:14:49.129 luup_log:135: VeraConnectWWN::getNestStreamPids> Got output: 19093
50 06/01/17 12:14:49.129 luup_log:135: VeraConnectWWN::isStreaming> Streaming: true <0x74a9f520>
50 06/01/17 12:14:59.128 luup_log:135: VeraConnectWWN::getNestStreamPids> Got output: 19093
50 06/01/17 12:14:59.129 luup_log:135: VeraConnectWWN::isStreaming> Streaming: true <0x74a9f520>
50 06/01/17 12:15:09.129 luup_log:135: VeraConnectWWN::getNestStreamPids> Got output: 19093
50 06/01/17 12:15:09.130 luup_log:135: VeraConnectWWN::isStreaming> Streaming: true <0x74a9f520>
50 06/01/17 12:15:19.129 luup_log:135: VeraConnectWWN::getNestStreamPids> Got output: 19093
50 06/01/17 12:15:19.129 luup_log:135: VeraConnectWWN::isStreaming> Streaming: true <0x74a9f520>
50 06/01/17 12:15:29.129 luup_log:135: VeraConnectWWN::getNestStreamPids> Got output: 19093
50 06/01/17 12:15:29.129 luup_log:135: VeraConnectWWN::isStreaming> Streaming: true <0x74a9f520>
50 06/01/17 12:15:39.129 luup_log:135: VeraConnectWWN::getNestStreamPids> Got output: 19093
50 06/01/17 12:15:39.130 luup_log:135: VeraConnectWWN::isStreaming> Streaming: true <0x74a9f520>
50 06/01/17 12:15:49.129 luup_log:135: VeraConnectWWN::getNestStreamPids> Got output: 19093
50 06/01/17 12:15:49.129 luup_log:135: VeraConnectWWN::isStreaming> Streaming: true <0x74a9f520>
50 06/01/17 12:15:59.141 luup_log:135: VeraConnectWWN::getNestStreamPids> Got output: 19093
50 06/01/17 12:15:59.142 luup_log:135: VeraConnectWWN::isStreaming> Streaming: true <0x74a9f520>
50 06/01/17 12:16:09.141 luup_log:135: VeraConnectWWN::getNestStreamPids> Got output: 19093
50 06/01/17 12:16:09.142 luup_log:135: VeraConnectWWN::isStreaming> Streaming: true <0x74a9f520>
50 06/01/17 12:16:19.130 luup_log:135: VeraConnectWWN::getNestStreamPids> Got output: 19093
50 06/01/17 12:16:19.130 luup_log:135: VeraConnectWWN::isStreaming> Streaming: true <0x74a9f520>
50 06/01/17 12:16:29.129 luup_log:135: VeraConnectWWN::getNestStreamPids> Got output: 19093
50 06/01/17 12:16:29.130 luup_log:135: VeraConnectWWN::isStreaming> Streaming: true <0x74a9f520>
50 06/01/17 12:16:39.130 luup_log:135: VeraConnectWWN::getNestStreamPids> Got output: 19093
50 06/01/17 12:16:39.130 luup_log:135: VeraConnectWWN::isStreaming> Streaming: true <0x74a9f520>
50 06/01/17 12:16:49.129 luup_log:135: VeraConnectWWN::getNestStreamPids> Got output: 19093
50 06/01/17 12:16:49.130 luup_log:135: VeraConnectWWN::isStreaming> Streaming: true <0x74a9f520>
50 06/01/17 12:16:59.130 luup_log:135: VeraConnectWWN::getNestStreamPids> Got output: 19093
50 06/01/17 12:16:59.130 luup_log:135: VeraConnectWWN::isStreaming> Streaming: true <0x74a9f520>
50 06/01/17 12:17:09.131 luup_log:135: VeraConnectWWN::getNestStreamPids> Got output: 19093
50 06/01/17 12:17:09.131 luup_log:135: VeraConnectWWN::isStreaming> Streaming: true <0x74a9f520>
50 06/01/17 12:17:19.129 luup_log:135: VeraConnectWWN::getNestStreamPids> Got output: 19093
50 06/01/17 12:17:19.130 luup_log:135: VeraConnectWWN::isStreaming> Streaming: true <0x74a9f520>
50 06/01/17 12:17:29.149 luup_log:135: VeraConnectWWN::getNestStreamPids> Got output: 19093
50 06/01/17 12:17:29.150 luup_log:135: VeraConnectWWN::isStreaming> Streaming: true <0x74a9f520>
50 06/01/17 12:17:39.130 luup_log:135: VeraConnectWWN::getNestStreamPids> Got output: 19093
50 06/01/17 12:17:39.130 luup_log:135: VeraConnectWWN::isStreaming> Streaming: true <0x74a9f520>
50 06/01/17 12:17:49.130 luup_log:135: VeraConnectWWN::getNestStreamPids> Got output: 19093
50 06/01/17 12:17:49.131 luup_log:135: VeraConnectWWN::isStreaming> Streaming: true <0x74a9f520>
50 06/01/17 12:17:59.130 luup_log:135: VeraConnectWWN::getNestStreamPids> Got output: 19093
50 06/01/17 12:17:59.130 luup_log:135: VeraConnectWWN::isStreaming> Streaming: true <0x74a9f520>
50 06/01/17 12:18:09.130 luup_log:135: VeraConnectWWN::getNestStreamPids> Got output: 19093
50 06/01/17 12:18:09.130 luup_log:135: VeraConnectWWN::isStreaming> Streaming: true <0x74a9f520>
50 06/01/17 12:18:19.130 luup_log:135: VeraConnectWWN::getNestStreamPids> Got output: 19093
50 06/01/17 12:18:19.130 luup_log:135: VeraConnectWWN::isStreaming> Streaming: true <0x74a9f520>
50 06/01/17 12:18:29.129 luup_log:135: VeraConnectWWN::getNestStreamPids> Got output: 19093
50 06/01/17 12:18:29.130 luup_log:135: VeraConnectWWN::isStreaming> Streaming: true <0x74a9f520>
50 06/01/17 12:18:39.130 luup_log:135: VeraConnectWWN::getNestStreamPids> Got output: 19093
50 06/01/17 12:18:39.130 luup_log:135: VeraConnectWWN::isStreaming> Streaming: true <0x74a9f520>
50 06/01/17 12:18:49.129 luup_log:135: VeraConnectWWN::getNestStreamPids> Got output: 19093
50 06/01/17 12:18:49.130 luup_log:135: VeraConnectWWN::isStreaming> Streaming: true <0x74a9f520>
50 06/01/17 12:18:59.138 luup_log:135: VeraConnectWWN::getNestStreamPids> Got output: 19093
50 06/01/17 12:18:59.139 luup_log:135: VeraConnectWWN::isStreaming> Streaming: true <0x74a9f520>
50 06/01/17 12:19:09.130 luup_log:135: VeraConnectWWN::getNestStreamPids> Got output: 19093
50 06/01/17 12:19:09.131 luup_log:135: VeraConnectWWN::isStreaming> Streaming: true <0x74a9f520>
50 06/01/17 12:19:19.130 luup_log:135: VeraConnectWWN::getNestStreamPids> Got output: 19093
50 06/01/17 12:19:19.130 luup_log:135: VeraConnectWWN::isStreaming> Streaming: true <0x74a9f520>
50 06/01/17 12:19:29.130 luup_log:135: VeraConnectWWN::getNestStreamPids> Got output: 19093
50 06/01/17 12:19:29.130 luup_log:135: VeraConnectWWN::isStreaming> Streaming: true <0x74a9f520>
50 06/01/17 12:19:39.130 luup_log:135: VeraConnectWWN::getNestStreamPids> Got output: 19093
50 06/01/17 12:19:39.131 luup_log:135: VeraConnectWWN::isStreaming> Streaming: true <0x74a9f520>
50 06/01/17 12:19:49.129 luup_log:135: VeraConnectWWN::getNestStreamPids> Got output: 19093
50 06/01/17 12:19:49.130 luup_log:135: VeraConnectWWN::isStreaming> Streaming: true <0x74a9f520>
50 06/01/17 12:19:59.130 luup_log:135: VeraConnectWWN::getNestStreamPids> Got output: 19093
50 06/01/17 12:19:59.130 luup_log:135: VeraConnectWWN::isStreaming> Streaming: true <0x74a9f520>
50 06/01/17 12:20:09.130 luup_log:135: VeraConnectWWN::getNestStreamPids> Got output: 19093
50 06/01/17 12:20:09.131 luup_log:135: VeraConnectWWN::isStreaming> Streaming: true <0x74a9f520>
50 06/01/17 12:20:19.129 luup_log:135: VeraConnectWWN::getNestStreamPids> Got output: 19093
50 06/01/17 12:20:19.130 luup_log:135: VeraConnectWWN::isStreaming> Streaming: true <0x74a9f520>
50 06/01/17 12:20:29.081 luup_log:135: VeraConnectWWN::getNestStreamPids> Got output: 19093
50 06/01/17 12:20:29.081 luup_log:135: VeraConnectWWN::isStreaming> Streaming: true <0x74a9f520>
50 06/01/17 12:20:39.130 luup_log:135: VeraConnectWWN::getNestStreamPids> Got output: 19093
50 06/01/17 12:20:39.130 luup_log:135: VeraConnectWWN::isStreaming> Streaming: true <0x74a9f520>
50 06/01/17 12:20:49.129 luup_log:135: VeraConnectWWN::getNestStreamPids> Got output: 19093
50 06/01/17 12:20:49.130 luup_log:135: VeraConnectWWN::isStreaming> Streaming: true <0x74a9f520>
50 06/01/17 12:20:59.129 luup_log:135: VeraConnectWWN::getNestStreamPids> Got output: 19093
50 06/01/17 12:20:59.130 luup_log:135: VeraConnectWWN::isStreaming> Streaming: true <0x74a9f520>
50 06/01/17 12:21:09.130 luup_log:135: VeraConnectWWN::getNestStreamPids> Got output: 19093
50 06/01/17 12:21:09.130 luup_log:135: VeraConnectWWN::isStreaming> Streaming: true <0x74a9f520>
50 06/01/17 12:21:19.130 luup_log:135: VeraConnectWWN::getNestStreamPids> Got output: 19093
50 06/01/17 12:21:19.130 luup_log:135: VeraConnectWWN::isStreaming> Streaming: true <0x74a9f520>
