Pretty interesting possibilities if Vera could access all the sensors and the audio alert triggers…
I’ve been waiting for a good smoke detector…Links to your Nest auto-away as an added bonus! I’m in for three…
I will wait to see if a plugin can be created and what stuff it can access. $129 is a lot for that if it can only tell me there is smoke. If I can access the other stuff (humidity, motion, light), then it would be more than worth it, and I would consider adding one to every bedroom and then some in common areas. Might be overkill, but the extra sensors would be worth it.
That is a significant amount of money for a Smoke and CO alarm.
Yes it would be, except if you read the specs (or the thread title) it is much, much more.
Sent from my SGH-I747 using Tapatalk 2
I did.
I guess it depends on if you want those extra features and are willing to pay for it.
I wonder just how long certification took for this device to pass?
Hmm, it see it uses a photoelectric smoke detection to detect a fire. Too bad they didn’t also incorporate ionization smoke detection as well, then this device would be great.
For an explanation of both types of detectors, follow this link:
http://www.nfpa.org/~/media/Files/Safety%20information/Smoke%20Alarms/nfpasmokealarmfactsheet.pdf
