[quote=“TheGadgetGuy, post:120, topic:171456”]Regarding the “feature request” for the Nest plugin: This has nothing to do with folks having incompatible routers. That was not the point. The point is, Vera is going to only indicate the last information it receives from Nest’s server. The Nest solution is inherently less reliable because there are multiple points of failure. Thus the need to know how stale the data being presented is.
With Z-wave thermostats, there is a greater reliability factor because Vera is pinging the T-stat directly. If Vera can’t directly change the temperature of a Z-wave T-stat, it tells you.
Don’t get me wrong. I find the Nest to be a really cool device, and so far, it has been a pretty fun gadget to play with. In my line of work, the devil is in the details. If I am being presented information that is not “real time”, I’d like to know that.
Watou made a great plugin for the Nest, and I think we are all greatly benefiting from his efforts. Keep up the good work!! Thanks to your plugin, I’ll soon be buying a couple more Nests for other zones in my house.[/quote]
I agree that since both the plugin and the thermostat have to reach over the Internet to report properly, completely local solutions can be more reliable. But don’t get me wrong – regardless of how you resolve the issue with the Cradlepoint, I am definitely going to be providing usable information in an update to the plugin on how “stale” the thermostat status might have become due to connectivity problems. So at least you will know that you don’t know the current status when those failures occur. I think the issue of connectivity from your Vera to nest.com is addressed properly in the current version, but I will add the LastUpdate variable to the three device types to give information that automation can use for when your thermostat(s) can’t connect back to the mothership.
