Hello Just installed one of these everything seems ok but the switch on UI7 says armed\disarmed
Is this correct I was expecting open\closed
Nobber
That is correct, It is not a switch it’s a security sensor, it uses different variables
http://wiki.micasaverde.com/index.php/Luup_UPnP_Variables_and_Actions#SecuritySensor1
ok, thanks …again!
Arm and disarm don’t affect the actual sensor, only what Vera does in response to a trigger from that sensor. An armed sensor always generates an alert entry. The state of the armed variable allows for more complex triggers for scenes or plug-ins.
Ok thanks
Nobber
What is it with this Neo Cr$p When I first installed it 2 hours ago it was working fine, as soon as I moved the magnet away from the sensor it detected, 2 hours later nothing!
The light comes on the sensor itself but does not show in the UI and doesnt notify
AAAAAAAArghhhhhhhhhh, I Have similar problems with New plugs
Anyone else got this, is it the sensor or my Vera Plus
Nobber
The problem you’re describing seems to be common with this sensor. Amazon has a number of critical reviews.
thanks, I’ll check those out
anyone got these setup and working for longer than a day
Nobber
Yup. 2 plugs for tvs and 3 sensors working ok since almost two years.
Nice are they uk plugs, when you get a moment would you mind posting the settings please - also are they on config - default Yes\No or auto config, thanks
I have the EU version, since I’m in Italy - but I think it’s the same firmware, since EU share the same Z-wave band.
Auto-configure is off (after I configured) and here’s my settings:
I even disabled the led (annoying as hell behind TVs) and the button, so it’s not accidentally turned ON/OFF.
The sensors are very similar. Just be sure to pair them really near your Vera hub.
thank you
Nobber
Strange I dont have any of these setting, I’ll try and delete\ reset then re pair
Be sure to select the appropriate device when paring, do not go with the generic device template.
Will do, but I think I did
Nobber
