I’ve installed the 3 different Logic plugins, all version 2.9.
The thing is that when I go into the Conditions on the Timer Switch plugin, I get the following message ‘You must also install the program logic core plugin’
When ever you change the configuration for Vera (Not just the PL Plugins, but anytime you Add/Delete/Update a plugin, Add/Delete a device)
It’s always best to do the following:
[ul][li]Restart Vera
Vera does not provide the plugins an event that let’s them know things have changed.
Sometimes they need a restart to notice.[/li]
[li]Reload your Browser
Vera Caches data in the browser.
Sometimes the data is old … and needs to be reloaded to get a fresh set of data.[/li][/ul]
