Need help with understanding why some simple conditions are failing
I have an entry in my Google calendar which started today and goes until the end of the month signifying that it’s Halloween season. I thought I had the conditions set so that a different set of scenes would run when the google calendar zwith for said event was triggered. Alas, I came home today to find thatno scene was run at all. Not the expected Halloween one or the regular one. Could anyone help shed some light on this?
Attached is the report.
Entry Management
Device ID: 462013-10-15 17:36:42.732 PLC Version: 5.1
Triggers
Name Description
Aurora_Entered PIN Code #2 is entered on The Side Door Lock
Walden_Entered PIN Code #4 is entered on The Side Door Lock
Deb_Entered PIN Code #5 is entered on The Side Door Lock
Halloween_Time Halloween Time: Armed calendar event is Active
Colin_Entered PIN Code #1 is entered on The Side Door Lock
Conditions
Name Expression
_ColinEntered Colin_Entered and (NOT Halloween_Time)
_HalloweenColinEntered Colin_Entered and Halloween_Time
_AuroraEntered Aurora_Entered and (NOT Halloween_Time)
_HalloweenAuroraEntered Aurora_Entered and Halloween_Time
_WaldenEntered Walden_Entered and (NOT Halloween_Time)
_HalloweenDebEntered Deb_Entered and Halloween_Time
_DebEntered Deb_Entered and (Not Halloween_Time)
Actions
Actions for Condition: _ColinEntered
Immediate
Device Action Arguments
Entry Management RunScene SceneNameOrNumber=4
Actions for Condition: _HalloweenColinEntered
Immediate
Entry Management RunScene SceneNameOrNumber=44
Actions for Condition: _AuroraEntered
Immediate
Entry Management RunScene SceneNameOrNumber=5
Actions for Condition: _HalloweenAuroraEntered
Immediate
Entry Management RunScene SceneNameOrNumber=43
Actions for Condition: _WaldenEntered
Immediate
Entry Management RunScene SceneNameOrNumber=18
Actions for Condition: _HalloweenDebEntered
Immediate
Entry Management RunScene SceneNameOrNumber=47
Notifications
Name Description Users Last Sent
Aurora Entered Entry Management has satisfied condition: _AuroraEntered Erasmus 2013-10-11 16:07:39.545
Please show the status … not just the report … We can then see what fire last and why.
Ahh. Yes indeed.
It says my last entry was last night, but that’s not the case. Also it says that my daughter’s last entry is still true. I’m assuming this has something to do with the issue.
Entry Management
Device ID: 462013-10-15 18:09:12.666 PLC Version: 5.2
Triggers
Name Description Last Trigger State
Aurora_Entered PIN Code #2 is entered on The Side Door Lock 2013-10-15 11:06:48.387 true
Walden_Entered PIN Code #4 is entered on The Side Door Lock 2013-09-13 15:56:38.607 false
Deb_Entered PIN Code #5 is entered on The Side Door Lock 2013-10-11 21:00:59.964 false
Halloween_Time Halloween Time: Armed calendar event is Active 2013-10-15 00:00:00.134 true
Colin_Entered PIN Code #1 is entered on The Side Door Lock 2013-10-14 20:43:41.667 false
Conditions
Name Expression Last True State
_ColinEntered Colin_Entered and (NOT Halloween_Time) 2013-10-14 20:43:41.669 false
_HalloweenColinEntered Colin_Entered and Halloween_Time 2013-10-15 00:00:00.138 false
_AuroraEntered Aurora_Entered and (NOT Halloween_Time) 2013-10-11 16:07:39.545 false
_HalloweenAuroraEntered Aurora_Entered and Halloween_Time 2013-10-15 11:06:48.399 true
_WaldenEntered Walden_Entered and (NOT Halloween_Time) 2013-09-13 15:56:38.621 false
_HalloweenDebEntered Deb_Entered and Halloween_Time 0 false
_DebEntered Deb_Entered and (Not Halloween_Time) 2013-10-11 21:00:59.980 false
Actions
Immediate
Immediate
Immediate
Immediate
Immediate
Immediate
Notifications
Looks like your lock is not reporting events … battery or connectivity problems ?
Hmmmmmmm. Not connectivity as the lock and Vera are separated by 10’ and the battery should be and is reported as fine.
I’ll experiment more and report back.
