I never tried to use the blaster with vera, instead I use the vera with SQRemote. But this requires iOS devices to install the SQRemote on.
So what I do is to trigger Scenes and IR from by iPad/iPhone not start a scene on Vera which involves IR on the Blaster.
I hope you understand what I mean.
If you need any more help, I will try to.
Cheers
Umtauscher
What you want to do is possible, i have done it, but it is very long winded and complicated (at least for me it was). I am not sure i would be able to do it again, or would want to. I think the instructions of how to are here on this part of the forum. If i find them i will add a link to my post
the sqblaster learns the code from remote control of my Air Conditioning System Brand: Komeco, but when emitted by sqblaster this code learned do not works nothing in the device.
I try at least 3 sqblasters devices and 3 differents units of that air conditioning…
someone can helps or someone past by this problem ??
I dont think SQ blaster works with AC units due to the AC’s IR codes being a different format i think. I think you might have to use something like a Remotec ZXT120, which specifically for AC ir control
Sorry i have no experience with iTach. And what i said about the SQ blaster not working with AC units is only what i read here… someone explained why it would not work. Have a search on here, that might give you more information, i cannot remember where i read this
