Hi all,
currently I am not using a Z-Wave gateway because some of my equipment is not yet supported by Vera. Instead I use 4-gang radio transmitters Merten 506004 as controller to switch or dim my lamps. Now I bought some Fibaro FGR221 to control my roller shutters too. After installation with mono-stable switches and inclusion into my network using Merten CONNECT USB dongle and configurator I am able to remotely control my roller shutter. Unfortunately roller shutter moves up or down for only 2.5 seconds. The same occurs when locally pressing the switches and even if I replace the motor for testing purposes with lamps. Regarding to support of Fibaro this is because I am using roller shutter motors with electronic limit switches, which is correct. They recommend to disable positioning (set parameter 10 of each roller shutter to OFF). Merten software does not allow to change such parameters.
Are there any users of Vera which are sucessfully using a combination of FGR221 and roller shutter motors with electronic switches? Did you noticed a similiar behaviour before disabling positioning? Is there an alternative method to position the roller shutter, e.g. by time?
If this is possible I have to decide to buy Vera and use the cumbersome method to configure my network with Merten connect software and transfer it to Vera (using option Z-Wave Settings/Advanced/Copy Z-Wave network from master controller). Fibaro HC2 does not fit my budget and it is not yet proved to support all the Merten stuff correctly.
Thank you for your responses,
Sebastian.
[Merten CONNECT radio USB data interface with CONNECT radio configurator, Merten 4-gang radio transmitter 506004, Merten universal dimmer 507900, Merten radio receiver, 2-channel switch 507502, Fibaro roller shutter controller FGR221]
