Need Help With Large Home Installation
Hey guys I need some help on this one. I have a range issue. This is a 6000 sqf home with a large back yard. I am using ca600 light switches and one intermatic outlet. I am attaching a link with a photo of the lay out. Trying to get all switches and broaded my range of the vera lite. Any help would be greatly appreciated. Thanks Guys
[url=https://plus.google.com/photos/107265588321809707216/albums/5860523650853738529?authkey=COTC6sWBhoLGzQE]https://plus.google.com/photos/107265588321809707216/albums/5860523650853738529?authkey=COTC6sWBhoLGzQE[/url]
If it was me I would take my address off the map you posted, maybe you don’t mind but I wouldn’t want my address on a public forum. Adding an external Antenna on your Vera light will help the most with range. Check the thread below for details.
http://forum.micasaverde.com/index.php/topic,11276.0.html
This page has some good photos of the inside of the Vera Lite and the extended Antenna.
http://forum.micasaverde.com/index.php/topic,11276.75.html
I may be wrong but wont the zwave switches extend the range? Or is that just a myth?
Yes, switches work as repeater for z-wave signals. There is a limitation on no. of hops I guess.
As it sits right now, I have a hard time reaching front door light. As well as have a hard time reaching pool lights. I placed possible switch locations to get me to the pool. Do you think I should upgrade my antenna?
3 Hops, the last device is device numer 4 ( if I am correct)… there is also a possibility to do manual routing… some topics about it in this forum.
Cor
rather than playing with the antenna, it might make more sense for large houses to have 2 or more Veras and bridge them: http://wiki.micasaverde.com/index.php/Bridged_Mios_Engines . Also searching the forums you’ll find good discussion on this.
Smarthomesd,
How many devices you have installed now ?
I only have 4 devices, 3 CA600 and 1 ca 3500. They are labeled on picture as SW. Then I labeled the possible locations of other switches. I have thought of buying another vera as well. But if just adding more switches is going to work I’d like to try that first.
I like to use a portable module like this GE/Jasco Outdoor Module or this GE/Jasco Lamp Module to test routing node locations when trying to improve coverage. The portable modules allow me to move the Z-Wave node to multiple locations, finding the best one, before installing a permanent node such as a socket or switch.
Just remember to heal the network for the route changes to take effect. Or leave the module in place overnight for the same reason.
I think adding more devices turn your netowrk more reliable
I have installed 2 Veras for 300m2 3-storey house before. I believe 3 or more Veras would be minimum for 6000sqf home with large backyard.
Awesome guys appreciate all the feed back looks like I have a couple options. I’ll start with adding devices around, then possibly grab another vera lite
Just as a side note, which I didn’t know when I added my second vera. The devices are working on a different mesh network and don’t communicate which each other, but only to their respective vera where they have been included… so a hop from a device included in one vera cannot be used as a hop for a device which is included on the second vera!
Hope it makes sense what I write :-s
Cor
