Finally had the time to play with that Mode Plugin and it still doesn’t seem to be doing what I need it to. Let me try to explain what it is exactly that I’m trying to do again.
Devices: Thermostat, Door Lock, Deck Light, Garage Light, Exterior Entry Light, Interior Entry Light
When I hit the HOME mode button and it’s DAY TIME I’d like the system to:
- set the thermostat to 70 degrees
- no change to door lock
- poll the light switches to make sure they are all turned off
Then from that point I’d like the system to:
- Turn the Deck light, garage light and Entry lights on at NIGHT and off at DAY
When I hit the HOME mode button and it’s NIGHT TIME I’d like the system to:
- poll the light switches and turn the deck light (100%), garage light and entry lights on (25%) if they aren’t already set
Then from that point after I’d like the system to:
When I hit the AWAY mode button and it’s DAY TIME I’d like the system to:
- set the thermostat to 58 degrees
- lock the door
- poll the light switches to make sure they are off
- Turn the garage light and Entry lights on at NIGHT and off at DAY
When I hit the AWAY mode button and it’s NIGHT TIME I’d like the system to:
- lock the door
- turn on the garage lights and entry lights (or since they will most likely already be on, set the deck lights off and the garage and entry lights on)
What I have currently are scenes created for the daily turning on and off of the lights using the Day/Night plugin as a trigger(and this has been working just fine)
I’ve changed the Modes to DEFAULT from the dashboard
I’ve created scenes using the HOUSE MODES plugin.
- one for Home - Day
- one for Home - Night
- one for Away - Day
- one for Away - Night
Because I don’t want lights to come on when I hit a mode button unless its night time. I also include the Day/Night as a trigger.
This didn’t work. The thermostat and door lock changed using the the HOUSE MODES scenes but that also worked when I set those directly as a custom setting in the Modes directly. The light configuration did not change however. I could not set the lights directly in the custom setting of the modes directly because I don’t want the lights to come on if I hit the Away button and it’s the day time.
I’m just frustrated with the fact the system ONLY uses triggers to make things happen during the time of day. I would be nice if the system would query the Day/Night plug in no matter what time of the day you choose the button and set the lights according to the scenes set for Day or Night. Right now if I have all the lights on because it’s night and I’m in Home mode and I leave at night and I hit the NIGHT mode button it does not turn off the deck lights. I have to do that manually. It works ok during the day because the scene already turned all the lights off so changing to away mode will just set the system for the next trigger point which would be NIGHT in the Day/Night plugin.
I hope I’m making sense here.
Thanks again for the help.
