In my electrical box, I have two red wires, 1 ground, and I have identified the neutral wires (not wired to the original light switch). My Jasco 45609 switch has ground, load, hot line, and neutral wire terminals. It also has a traveler terminal that I will leave blocked off as it is not a 3-way switch configuration. I am not a home electrician and would like to get some specific guidance of which wires I need to connect to what. Obviously I understand the ground to ground, and neutral to neutral terminals, but I am doing something wrong with the two red wires. Where do they connect?
Disregard! I didn’t realize this switch was a dual pole momentary switch… I was pressing the off button the whole time! The wemo switches that I’m accustomed to are single pole momentary…
