Need help with an aeon siren
Ok so I have an Aeon siren (zw080) connected to my Vera edge and I’m have it connected to some door sensors via a scene so that in away mode if the doors open the siren sounds however the siren sounds like a smoke alarm at the moment and I would like it to sound more like an intruder alarm and for it to be set at its max volume level. Does any body know how to do this.
Sorry I’m a noob at this if you need more info just let me know and il look at it.
Thanks in advance.
Hey I’m still new also, if you are in UI5 right now maybe this will help.
http://www.vesternet.com/resources/application-notes/apnt-90
Right now I’m doing some scene experiments. Hope this helps ;D
It’s in the middle already tried it. It seems you can pick the sounds and just add it to the configuration nodes. Just go to the device > Device Options > Check the node 37 > Change the value to the parameter you want and Bam you got your sound. I’m using UI 7 right now it still works. :smiley:
