Need help to reinstalla Eventwatcher
I have been using Eventwatcher for several years now, great app!
However, my Vera almost died during a beta upgrade and was restored. Now I get the following message when trying to install the app again: Event Watcher[1849] : Startup Lua Failed
I am using the last Stable firmware on a Vera Plus.
Advise needed!
Not sure what that might be. A copy of the relevant lines from the log might help.
The version on the MiOS app store is not a recent one - it’s just too hard to update. I’d suggest that if you use AltUI, then get it from the AltAppStore. Otherwise install files manually from the GitHub development repository…
