Ok, an update. I figured out the location mapping, by reading the manual again, that’s my bad. However , I am at the same place where I was when I tried to make it work a few months ago. Here is what I am seeing in the luup debug log when I try to get it going:
50 07/12/14 14:13:56.573 luup_log:21: Initializing Caddx NX-584 LEAK this:118784 start:450560 to 0x9aa000 <0x2b6c3680>
50 07/12/14 14:13:56.577 luup_log:21: Opening serial port <0x2b6c3680>
50 07/12/14 14:13:56.578 luup_log:21: Sending message and waiting for response: 0x21 Interface Configuration Request <0x2b6c3680>
50 07/12/14 14:13:56.579 luup_log:21: Message: Outgoing: 0x7e 0x01 0x21 0x22 0x23 <0x2b6c3680>
50 07/12/14 14:13:58.268 luup_log:21: Received inconvenient message 0x06 LEAK this:217088 start:667648 to 0x9df000 <0x2b6c3680>
50 07/12/14 14:13:58.269 luup_log:21: Message: Unsolicited message body: 0x00 0x20 0x00 0x00 0x40 0x01 0x04 0x80 <0x2b6c3680>
50 07/12/14 14:13:58.269 luup_log:21: Sending message: 0x1D Positive Acknowledge <0x2b6c3680>
50 07/12/14 14:13:58.269 luup_log:21: Message: Outgoing: 0x7e 0x01 0x1d 0x1e 0x1f <0x2b6c3680>
50 07/12/14 14:13:58.271 luup_log:21: Message: Outgoing: 0x7e 0x01 0x21 0x22 0x23 <0x2b6c3680>
50 07/12/14 14:14:00.761 luup_log:21: Received inconvenient message 0x06 LEAK this:32768 start:700416 to 0x9e7000 <0x2b6c3680>
50 07/12/14 14:14:00.762 luup_log:21: Message: Unsolicited message body: 0x00 0x20 0x00 0x00 0x40 0x01 0x04 0x80 <0x2b6c3680>
50 07/12/14 14:14:00.762 luup_log:21: Sending message: 0x1D Positive Acknowledge <0x2b6c3680>
50 07/12/14 14:14:00.763 luup_log:21: Message: Outgoing: 0x7e 0x01 0x1d 0x1e 0x1f <0x2b6c3680>
50 07/12/14 14:14:00.764 luup_log:21: Message: Outgoing: 0x7e 0x01 0x21 0x22 0x23 <0x2b6c3680>
50 07/12/14 14:14:03.264 luup_log:21: Received inconvenient message 0x06 <0x2b6c3680>
50 07/12/14 14:14:03.265 luup_log:21: Message: Unsolicited message body: 0x00 0x20 0x00 0x00 0x40 0x01 0x04 0x80 <0x2b6c3680>
50 07/12/14 14:14:03.265 luup_log:21: Sending message: 0x1D Positive Acknowledge <0x2b6c3680>
50 07/12/14 14:14:03.266 luup_log:21: Message: Outgoing: 0x7e 0x01 0x1d 0x1e 0x1f <0x2b6c3680>
50 07/12/14 14:14:03.267 luup_log:21: Message: Outgoing: 0x7e 0x01 0x21 0x22 0x23 <0x2b6c3680>
50 07/12/14 14:14:05.751 luup_log:21: Received inconvenient message 0x06 <0x2b6c3680>
50 07/12/14 14:14:05.752 luup_log:21: Message: Unsolicited message body: 0x00 0x20 0x00 0x00 0x40 0x01 0x04 0x80 <0x2b6c3680>
50 07/12/14 14:14:05.752 luup_log:21: Sending message: 0x1D Positive Acknowledge <0x2b6c3680>
50 07/12/14 14:14:05.753 luup_log:21: Message: Outgoing: 0x7e 0x01 0x1d 0x1e 0x1f <0x2b6c3680>
50 07/12/14 14:14:05.754 luup_log:21: Message: Outgoing: 0x7e 0x01 0x21 0x22 0x23 <0x2b6c3680>
50 07/12/14 14:14:08.252 luup_log:21: Received inconvenient message 0x06 <0x2b6c3680>
50 07/12/14 14:14:08.253 luup_log:21: Message: Unsolicited message body: 0x00 0x20 0x00 0x00 0x40 0x01 0x04 0x80 <0x2b6c3680>
50 07/12/14 14:14:08.253 luup_log:21: Sending message: 0x1D Positive Acknowledge <0x2b6c3680>
50 07/12/14 14:14:08.253 luup_log:21: Message: Outgoing: 0x7e 0x01 0x1d 0x1e 0x1f <0x2b6c3680>
50 07/12/14 14:14:08.254 luup_log:21: Message: Outgoing: 0x7e 0x01 0x21 0x22 0x23 <0x2b6c3680>
50 07/12/14 14:14:10.753 luup_log:21: Received inconvenient message 0x06 <0x2b6c3680>
50 07/12/14 14:14:10.754 luup_log:21: Message: Unsolicited message body: 0x00 0x20 0x00 0x00 0x40 0x01 0x04 0x80 <0x2b6c3680>
50 07/12/14 14:14:10.754 luup_log:21: Sending message: 0x1D Positive Acknowledge <0x2b6c3680>
50 07/12/14 14:14:10.755 luup_log:21: Message: Outgoing: 0x7e 0x01 0x1d 0x1e 0x1f <0x2b6c3680>
50 07/12/14 14:14:10.756 luup_log:21: Message: Outgoing: 0x7e 0x01 0x21 0x22 0x23 <0x2b6c3680>
I have the Vera Lite directly connected to the NX-584 via pl2303 and female/female serial adapter. There is no cable involved, other than the usb/serial adapter. I have the jumpers opposite of default on the nx-584. I have tried reversing them, when I do that I get an error initializing the interface. I have also programmed the NX-584 on my NX-8V2 by doing the following:
- *8
- program code 9713 (this is the default and works still)
- 72# (this is the address for the NX-584E according to the manual)
- Entered the following based on Eddie’s recommendations, except I left it at 9600 baud:
Location 0=blank (binary)
Location 1=4 (9600 baud)
Location 2, Segment 1 = 2,5,6,7,8
Location 2, Segment 2 - 1,3,4
Location 3, Segment 1 = 2,4,5,6,7,8
Location 3, Segment 2 = 1,2,3,4,5
Location 3, Segment 3 = 1,2,3,5,7
Location 3, Segment 4 = 3,4,5,6,7,8
I left location 4 as defaults. Attached is a screenshot of the serial port config. Any ideas on what I am missing? Thanks!
