I have a schedule sNight set to condition cNight (repeating), a trigger tJustHome set to a condition cJustHome and a device property check pGarageFloodChk set to condition cGarageFloodChk (repeating).
I want the flood to go on when it’s night time, I just get home and it’s off.
cGarageFloodLate is defined as cNight AND cJustHome and cGarageFloodChk.
Even when all conditions are TRUE and cGarageFloodLate is TRUE the action doesn’t fire. I tried to troubleshoot cNight as the only condition to turn the virtual switch on and even though cNight was true, cGarageFloodLate defined as cNight was false.
I did get this to work. BUT - I don’t understand exactly why or if there is a more elegant way to do it. I ended up doing a logic test in the condition statement to make sure that one of the elements in the condition triggered an evaluation.
I’m testing for three conditions. The geofence triggers a scene that turns a virtual switch to on for home status (tHome).
cNight {is it night}
cGarageFloodChk {garage flood is off}
(tHome,NOW<1:00) {I just got home}
cNight AND cGarageFloodChk AND (tHome,NOW<1:00)
Is this saying that the tHome and NOW<1:00 timestamps need to be within a minute of NOW? Does this work because NOW<1:00 is always TRUE?
Prior to putting the logic test in the condition statement this condition would only trigger an action if I manually toggled the Day or Night plugin to Night (or from Night to Day and back to Night if it were night already).
