I have one device showing up called “_Appliance Module”, that says "Unable to get any information on node.
I remove it, and it keeps coming back… I can’t figure out what device it is as all of mine are accounted for.
Do you have a mimolite? I have one controlling my gate and have an appliance module associated with the mimolite that is distinct from the garage door plugin
[quote=“johnes, post:1, topic:182953”]I have one device showing up called “_Appliance Module”, that says "Unable to get any information on node.
I remove it, and it keeps coming back… I can’t figure out what device it is as all of mine are accounted for.[/quote]
Post some more info on it and what you have.
So it ended up being a foscam camera… ended up deleting it via: http://<local_Vera_IP>:3480/data_request?id=device&action=delete&device=<device_ID>
For whatever reason, I haven’t been able to get my cameras added, and when I hacked somethign together manually, it caused them not to be able to be deleted…
[quote=“johnes, post:4, topic:182953”]So it ended up being a foscam camera… ended up deleting it via: http://<local_Vera_IP>:3480/data_request?id=device&action=delete&device=<device_ID>
For whatever reason, I haven’t been able to get my cameras added, and when I hacked somethign together manually, it caused them not to be able to be deleted…[/quote]
That’s common. POS foscam’s cause me problems too, but not anymore problems in VERA atleast now that I use the Blueiris Plugin.
