Hey guys - When Hek came up with this stuff it fulfilled a long dream of mine to integrate arduinos with Vera - even better with them being wireless!!!
I guess i consider myself a hacker… Ive loads of ideas on how i could measure,automate and analyse data in our physical world but never enough time!
Unfortunately i’m rubbish at programming but can “hack” enough together to do what i need to do…reasonably easily since its cut n’ paste, test,fix,test again and so on!
But to me the hardest thing to do with these projects is implement the circuit from breadboard into a device in a safe, nice looking and robust manner!
Putting designs together on veroboard sux! I can solder a pcb with 100 component in minutes ( neatly and without dry joints…ive been soldering for over 35 years, im only 41yrs young now ) but it kills me building on veroboard!
Anyway, i thought its about time i learned how to make PCB’s!!
So in the last few days ive learnt how to use some online design, “circuits.io” ( recently bought by Autodesk )
With this software i have created a design that should make putting together Hek’s and your own circuits quickly and easily. Basically the PCB hosts a Nano, radio, capacitor and a bunch of headers.
Here is the link:
You should be able to create a login ( google/fb/ email etc ) and see the design.
My idea is to build the pcb using headers allowing nanos, and radios we have bought from ebay etc to plug in.
You would likely just solder the capacitor direct onto the pcb.
Also the Jumper headers are there to allow for pullup/pulldown resistors or resistor for Dallas temp sensor needs. So dont just install pin headers there if your just going to use a resistor!
The website allows you to buy the pcb’s as is (they say about 10-12 days) or you can fork the design for your own specific designs!
It allows you do download a Gerber file/s of your designs…i guess this allows you to get the pcb’s made elsewhere cheaper/quicker?
Anyway …bed time for me. Hope this is of value to others and is a small contribution to Hek’s awesome work!!
Lastly…pls check the design for errors. The only one i think is wrong is the polarity of the capacitor…i think its a bug in the software, but i couldnt be bothered changing it to a different component…
Enjoy!
