New variables are available for use and presumably there’s an update required to the Vera Plugin? Does anyone have any info if anyone is taking that on?
From a post I read at mysensors I should be using the UI7 version of the plugin since I’m on UI7. It is ahead of the development branch which is for 2.0. So I’m using the 2.0 mysensors and the UI7 vera plugin. You’ll need to change some things to get you sketches working.
