Hardware wise this project is VERY easy to complete. The hardest part was arranging the hardware to fit in the case. The sketch on the other hand was a pain in my butt and I’m sure it’s VERY inefficient, but does seem to work without ANY false alarms.
Thanks to BulldogLowell for the coding help!
Mod Goals:
- Detect when the siren is powered up and transmit that “trip” to Vera (for various processes)
- Use interrupt to start Arduino with a 9 hour “heart beat”.
- Utilize the detectors battery power.
Because this detector has on-board battery level checks and warnings, I don’t have to mess around with building a battery circuit.
BOM:
- Pro Mini
- I’m using Optocoupler for the speaker power isolation (you could probably just sense the 3.3v speaker voltage directly).
- Kidde Detector Used (any can be used providing you have the space inside)
More on the MySensors site
