Attached is an updated version of Macrho’s MyQ plugin that now out of the box also supports the Craftsman Assurelink system.
Note: At this time the app has only been tested under UI5.
I have updated Macrho’s original installation instructions and updated them to reflect the new Brand variable I added to the Advanced tab to be able to determine the brand. Valid entries for this field are Liftmaster, Chamberlain and Craftsman.
The rest of the plug-in has been left intact with the exception of setting the Authorization check time to 4 hours instead of 8 and the door status check to 5 minutes instead of 1 and a half minutes. The latter due to reports that Chamberlain may be blocking IP addresses of people banging their servers to often.
INSTALLATION INSTRUCTIONS:
The first step is to copy the files in the zip archive found below to your Vera
Navigate to the APPS tab in the Vera UI and then click on ‘Develop Apps’
Click on ‘Luup files’ and then upload the 6 lua, xml and json files:
-D_MyQGateway.json
-D_MyQGateway.xml
-I_MyQGateway.xml
-L_MyQGateway.lua
-L_MyQGateway_json.lua
-S_MyQGateway.xml
Scroll down a bit and check ‘Restart Luup after upload’ and then click the ‘Go’ button
If you want to use the icon with the device, use WinSCP or another app to ssh to your Vera box.
Copy the “MyQ_Gateway.png” file to /www/cmh/skins/default/icons/
]Now we have to create the device:
Click ‘Create device’ and:
- In the Description field type “MyQ Gateway”
- In the Upnp Device Filename type “D_MyQGateway.xml”
Finally, click the “Create device” button. A pop-up should occur with “Device created: Dev #”
Click “Reload” on the top right of the Vera UI
If all went right, you should see a warning at the top of the page:
MyQGateway: Username not configured. Password not configured. Brand not configured
Click on the wrench of the MyQ Gateway device and then click on the “Advanced” tab
If you don’t see a “Username”, “Password” or Brand entry under Variables, you’ll need to click on ‘Reload’ again.
Check the Advanced tab of the “MyQ Gateway” device and enter your username and password for MyQ/Assurelink.
Depending on the brand of your opener gateway enter one of the following values in the Brand field:
Liftmaster/Chamberlain MyQ opener - enter Liftmaster
Craftsman Assurelink opener - enter Craftsman
and then click on Save
Your Vera should startup again and create your children device, which are as many garage doors as you have associated to the gateway.
