My Notes on remote access for UI6
[quote=“RichardTSchaefer, post:60, topic:181032”]From querying https://vera-us-oem-autha11.mios.com I get the Server_Account and PK_Account … at the same time as I get the Identity and IdentiySignature
I query the Server_Account with /account/account/account/{{PK_Account}}/devices"
From there I get the Remote Gateway AND LOCAL IP Addresses of all of the devices.
I have used the Locator in the past … but since I do not use it … I never wrote down the tricks.[/quote]
Rich, Thanks for the info. I went that route as well. It took me some time of playing with things but I got it all worked out.
For me this script worked with errors like:
parse error: Invalid numeric literal at line 1, column 20
But i get another solution:
I’m reading through the discussion topic but can’t seem to find Richard’s notes addressing the remote access issue. Does anyone have it still? I’d really appreciate if someone could email me the notes (alysonfs@gmail.com) or attach them here somewhere.
Thank you!!
This is from old forum, not all files made it across
http://forum.micasaverde.com/index.php/topic,24942.0.html
here is a copy of the txt file if you do not have a login for old forum.
UI6Connect.txt.zip (3.2 KB)
Thank you so much! I didn’t have access to old forum…
