Starting off with small steps just to do something simple, but I get “PLEG startup failed”
I just took a wired door senser (Main Entry) and simply wanted to turn on a VS switch when the Main Entry was tripped. Can’t get more basic than that (I thought)
In PLEG I did the following: Inputs (Device Properties) - created Main Entry, tripped Inputs (Triggers) - selected Main Entry sensor, a sensor is tripped, device is tripped *I named it MainEntryTrip and clicked Accept which changed the name to MainEntryTrip1
Conditions - c1 (I named LightsOn) and Expression I put MainEntryTrip1 Actions - I selected LightsOn from the drop down and clicked VS_1 “On”
Then I saved , Lua restarted and errored out “PLEG startup failed”
What did I miss just to get this simple function to work???
I deleted the PLEG I was trying to program. I also deleted the trigger from Vera.
Then I created a new PLEG and programmed the same way.
It is now working fine for this simple set up.
One question… In the PLEG under Inputs;Device Properties, I left this blank. Before I had also added my door sensor.
What is this Device properties used for? Without adding anything there now this PLEG is working.
With a new browser instance … open the Vera control panel.
Open the [b]PLEG[/b/] Control.
Goto the Advanced Tab
Be careful to get get all of the following information and paste it into an email for me:
The value of each of the following variables (They can be long):
ConditionMap
ObjectStatusMap
Properties
Actions
