With the help of MySensors.org I’ve completed 2 sensors and the gateway. Here are some pictures of the first. Bottom line… If I can do it, so CAN YOU! ![]()
Don’t know how to imbed so here are the links…
I am now also building the arduino things … just finished a servo actuator ;D
Thinking now about a temperature sensor , can you tell me how the accuracy is , is it whole degrees like all vera devices, or is it tenth of degrees with “my sensor plugin”
Thanks,
Cor
1/10ths
[quote=“ServiceXp, post:1, topic:182494”]With the help of MySensors.org I’ve completed 2 sensors and the gateway. Here are some pictures of the first. Bottom line… If I can do it, so CAN YOU! ![]()
Third[/quote]
Looks great, I am planning on building a few!
looks good… i just purchased the parts for my gateway and a few sensors.
how is battery life so far?
