My EZLO Plus can not tell time. When I received our new EZLO device, I started by setting up a number of devices and scenes to match several of those that I had on our Vera Plus, but quickly found that none of them operated when they were scheduled to operate. Manual events worked great. Timed events? No!
While trouble shooting, I pressed the “reset” button on the EZLO Plus, not realizing that it would wipe hours and hours of my work, but it did. DON’T DO THAT, if you don’t want to start over!
Here is what I’m experiencing.
SCENES BASED ON SUNRISE - I have scenes created that start with a “Before sunrise”, “At sunrise” and “After sunrise”, and EVERY ONE OF THEM, without exception, executes an HOUR AND TWELVE MINUTES LATE! Since I started over, four days ago, this has been 100% the case.
SCENES BASED ON SUNSET - I have scenes created that start with a “Before sunset”, “At sunset” and “After sunset”, and EVERY ONE OF THEM, without exception, executes NINE MINUTES LATE! Since I started over, four days ago, this has been 100% the case.
SCENES SET TO RUN AT A PARTICULAR TIME EACH DAY - I have several scenes created that start at various times of the day, and EVERY ONE OF THEM, without exception, executes FOUR HOURS AND TWENTY-ONE MINUTES LATE! Since I started over, four days ago, this has been 100% the case.
I am at a loss!! I’ve added a couple from time to time over the past four days, but every one of them acts exactly the same! I have stopped my migration project until the developers can figure out how I can fix this problem. They are working hard to help all of us, but I’m not sure the EZLO is going to be in our home, to stay. And with Vera devices no longer available, I quite frankly don’t know where to turn. Let’s pray their talent pulls us thru and we end up with a good product that will work well!
