I have 4 Vera’s bridged running my home. Are you planning on supporting this like Square does?
aschwalb…
if do not…how can I extend the range of vera3 ? have some resource for this…
Doesn’t the master Vera expose all controls on the slave ones?
If not, it would be worth supporting multiple units. I’ll look into it ![]()
what the way to create a network with multiple vera3 ?
upnp ?
I have a big appartment and have to use at least 4 vera3 .
[quote=“Piwtorak, post:4, topic:172766”]what the way to create a network with multiple vera3 ?
upnp ?
I have a big appartment and have to use at least 4 vera3 .[/quote]
good place to start: http://docs5.mios.com/doc.php?language=1&manual=1&platform=3Lite&page=multiple_units
I just purchased this app, and so far it’s working great with my vera lite over wifi.
However, I have another vera 2 at my vacation home and I’d like to be able to control it with the same app. Is this possible?
It’s not possible (yet) to control 2 veras at the same time. However, you can save any HomeWave setup (controls, Vera details and MiOS credentials) to Dropbox or your phone’s internal memory, which would allow you to set up and save configurations for your 2 Veras, and swap between them by loading the corresponding config file.
